how to take off stock radio for 95 integ ls
Darnit I can't think of the site that has all the instructions I'm sure someone will remember it. Crutchfield has master sheets which are basically the same thing and very detailed telling you where every screw and everything is you can probably get if you call them. I know they send you one when you buy a radio.
you have to take out the shifter console, armrest, and everything else that is a plastic part under the radio. the box under the radio is attached to it with two clips, one on each side, that are screwed in. and there are two bolts that attach the back bottom of the radio to a sheet metal bracket. it's about 16 bolts total, and it takes a while if you've never done it before. i had to drive around with all the pieces in my trunk and the bolts on the floorboards. it was weird.
all the bolts are metric. they are either 8 or 10s i cant remember which.
all you need is a 1/4" drive ratchet, a long extension (10" i can't remember), and a 1/4in. drive 8mm socket that swivels.....
start by looking behind your center console from the passengerside (your head has to be pretty much in the footwell) .
you will see your deck being held by two silver 8mm screws. once you located them make sure your ratchet is in the reverse position unscrew the screws and pull your deck out from the front....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ninjarich2 »</TD></TR><TR><TD CLASS="quote">all you need is a 1/4" drive ratchet, a long extension (10" i can't remember), and a 1/4in. drive 8mm socket that swivels.....
you will see your deck being held by two silver 8mm screws. once you located them make sure your ratchet is in the reverse position unscrew the screws and pull your deck out from the front....</TD></TR></TABLE>
i also agree.
i also agree.
Sorry I missed your post but if you still need it try here http://www.installdr.com/Insta....html It will be pretty much the same for a 95
94
94
