Something in my GSR tranny went
Old Sep 5, 2005 | 03:38 AM
Honda Bull's Avatar
Default Something in my GSR tranny went
So.... was at the track yesterday. On slicks. The car had made 30 passes on slicks and on the 31 she let go. But not without an 8.98 1/8th mile. So the **** clunks and carries on (bucks back and forth) while moving slowly.
Then... we drove it to a nearby place to leave it. On the way there, the car was trying to pull to the left, so I had the wheel turned a good bit to the right. Came up on a railroad bridge, and while going under it and crossing over a dip and potholes in the road, the tire(s) were howling. So then afterwards, when I applied some throttle in second gear, while the car is pulling to the left, it instantly pulled to the right. Let off and it went back to being pulled to the left.
So I'll find out probably tomorrow as to what the problem is. Cause we'll be pulling the tranny then maybe. I dunno.
PS: perhaps the Action 6-puck sprung had something to do with this mishap.
EDIT: The 30 passes on slicks had been a total from like 4 other days. It wasn't just one day of relentless beating.
Modified by HondaBullSQ at 10:08 AM 9/5/2005
Old Sep 5, 2005 | 05:23 AM
drdisco69's Avatar
Default Re: Something in my GSR tranny went (HondaBullSQ)
Ouch. When the clutch and tires don't slip, something has to evenutally... If it goes into all the gears ok, it sounds like a differential problem. No telling exactly what until you open it up though. Make sure the case isn't cracked either.
Old Sep 5, 2005 | 08:18 AM
mmuller's Avatar
Mad Scientist
Default Re: Something in my GSR tranny went (drdisco69)
maybe diff.
Old Sep 5, 2005 | 09:20 AM
D-Rob's Avatar
Default Re: Something in my GSR tranny went (mmuller)
Time for a Quaife, *****.
Love,
- Derek & Scott
Old Sep 5, 2005 | 10:23 AM
Tech6023's Avatar
the bucking is the center pin eating a away at the case
Old Sep 5, 2005 | 12:19 PM
Honda Bull's Avatar
Oh, Chr*st. My tranny is fooked.
Old Sep 6, 2005 | 04:50 PM
Honda Bull's Avatar
Only really had time to get everything but the tranny out tonight. As I was glancing into the diff from the passenger side, we had spun the driver side hub (with the axle still in it). I witnessed the gears in the diff spinning constantly but the passenger-side hub portion of the diff would only catch at times.
Wondering whether or not I broke the ring gear or countershaft?
Not gonna know exactly until we pull the tranny and tear her open. Just thought I'd update the process though.
Peace.
Old Sep 7, 2005 | 03:12 PM
Honda Bull's Avatar
For any future reference of Honda-tech members....
It was only the differential.
My theory... the spider gears in the diff finally buckled. Snapped a few off... think that a few got caught on the ring gear and pulled around the ring gear along the casing... along the way breaking some of the aluminum tranny casing off and pulling it through around the ring gear as well. Metal shavings and chunks all over the place. Counter shaft and all other gears were fine.
May my first B-series diff rest in peace.
Old Sep 7, 2005 | 09:15 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
take a pic and show the carnage.
Old Sep 18, 2005 | 09:38 PM
bootlegcivic's Avatar
Default Re: Something in my GSR tranny went (not so civic)
I just did the same thing but mine wouldn't drive at all even though it went into every gear
Dark_Teg
Transmission & Drivetrain
Oct 20, 2009 10:05 PM
98ekgsr617
10
Sep 5, 2009 12:14 PM
boosted91crx
Jul 19, 2009 09:27 AM
Blown90hatcH
Apr 25, 2006 12:01 PM
