ls motor only revs to 1.5k
so i just did an ls motor swap and before i was having injector problems but i got that fixed then it wouldnt start unless i cover the tb but thats fixed, i think.
so now i got the car idling fine at 700 but when i rev it, it only revs to 1500 then it just loses power and drops back down and sometimes stalls if i stay on the gas and if i get off the gas the idle will stablize. there are no codes. i used a timing light and it was all good.
anybody got any suggestions and whats wrong
oh i forgot to mention that when it hits 1.5k it starts to backfire or hit a rev limit or something that causes it to pop and then it loses power.
timing issues ? timing light on the crank shows that its timed good
what do you mean, plz elaborate ? dizzy wiring or ecu wiring ?
oh and before when it was running on only 2 injectors, it use to rev to 4k and start to lose power and start popping there
soldered all wiring between dizzy and ecu, still only revs to 1.5k
im getting a code 1, would that cause it to only rev to 1.5k ? if not do you have any other suggestions on what i could check
thanks i really appreciate your help, this has had me stumped for weeks and i need my car running
check if your camshaft timing is timed w/ the crank, the motor can still run fine at idle but up higher it can't w/ the timing off. recently I had my cams 180 degrees off w/ the crank died on and it still ran and idles fine but drivability is crap. so make sure. another thing is check if your spark plug wire is in the right slot.
just checked cam timing yesterday, all good. shot my timing light on it and put it to 16 BTDC. quadrupled checked my spark plug wires
does it sound like a timing issue or more air/fuel problem ?
just to remind, at 1.5k its not hitting a revlimiter, the rpms just drop like i let off the gas or something, it just loses power
did u check the wireing at the ecu?
i think u got one of those dpfi to mpfi wireing thats wrong
Pins B10 and B12 are empty. Unused pins can be taken from B2 or B11. Sometimes there is a unused wire at B12. Cut orange and white wires off at C1 and C2 and connect them to wires added at B10 and B12. Orange-B10. White-B12. Leave enough wire for next step.
Run wires from C1 and C2 on the ecu into the engine compartment. Label these wires for later use. Cut wires at A3 and A7 leave excess for later use. Run these wires into the engine bay and label them to be used later on .
Under the Hood
TPS and EACV plugs are too short and must be extended. Be sure to switch green/white and yellow/white wires on TPS since the dx turns the opposite way.
Injectors and injector resistor box
Connect the yellow/black wires from the two DX injector harnesses and run it to the yellow/black wire on the injector resistor box. Connect the yellow wire from the DX injector to the #1 injector (brown wire). Connect the red wire from the DX injector and run it to the #3 injector (blue wire). Connect the A3 wire to the #2 injector (red wire). Connect the A7 wire to the #4 injector (yellow wire). Connect the 4 red/black wires from injector resistor box to each injector.
Cylinder position sensor
Connect C1 to blue/green wire on cylinder position sensor plug. Connect C2 to blue/yellow wire on cylinder position sensor plug the rest of the wires are color matched for your dx to the si wires
THIS INFORMATION IS FOR RESOURCE AND PERSONAL USE. I AM NOT LIABLE FOR ANY DAMAGE TO YOUR CAR OR OTHER PROBLEMS RELARED TO THIS CONVERSION
TEAM P IMPORTS 2002
Under the Hood
TEAM P IMPORTS 2002
k i double checked my mpfi convertion wiring at the ecu and everything looked good, everything was in the right place
does it sound like a timing issue, or fuel issue ? like i said not hitting a revlimiter, just loses power at 1.5k
possiblely bad o2 sensor ? would that cause it ?
bad dist ?
the ecu was run in my friends car but that was like 3 years ago
bad dist ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civickiller »</TD></TR><TR><TD CLASS="quote">k i double checked my mpfi convertion wiring at the ecu and everything looked good, everything was in the right place
how about when u floor it
switch ur tps and map senor plugs around
u may have backwards
they are not backwards because this tb didnt have a map sensor on it so my map sensor is on hte firewall running off a vacuum hose. but i do have the map vacuum and the fpr on the same vacuum line, could that be it ?
it idles at 700 and when i floor it the rpms drop down to like 100 and jump up and down like surging between 300 and 100 and if i let off the gas the idle will stablize again but down at 500 instead of 700. sometimes it dies
i unplugged the tps and the idle dropped from 700 to 400 and as soon as i stepped on the gas it died.
the map sensor was working with the old motor, think it would go bad?
the one thing that im worried about is the o2 sensor, im getting a code 1, i have the o2 sensor up near the head because the exhaust mani is from a obd0.
would the 4 wire heated o2 sensor being that close to the head cause a problem like this ? causing it to read too rich or lean ?
do you know how to fix a code one, i followed my chiltons manual and it brought me to a code 43 and then follow that, the book said "go to fuel system supply" and thats where i get lost because idk where in the book to find that
Do you have a fuel pressure guage?It will idle on a few pound but won't rev that way.The o2 sensor won't have this dramatic effect even if its completely dead.
Glenn
Glenn
yup spoon_fed was helping me and we found out that if you cover the tb completely except for a couple 3/32 drilled holes in the plate it will rev up to 2k and it will hold it if we floor it and it wont die or go higher. but as soon as we remove the plate it will die or try it without the plate it will die
it won t be the o2 sensor u can unplug it and the car will idle and run fine
did u try leaving the map and tps senor unplug and starting the car (u have to floor it to get it started)
both at the same time or one and then another ?
do you think my obd0 firewall map sensor might not be reading as good as say a map sensor thats on the tb ?
