Will an Civic Si gauge cluster hook up to an H22 ECU?
Hi all. I have a '92 Civic DX hatch with an H22a swap. Right now I have an EG SiR JDM gauge cluster, but I would like to install a '99-'00 Civic Si gauge cluster. My questions are:
-will it hook straight up to the H22 ecu?
-what modifications are needed (if any)?
Thanks
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludepower »</TD></TR><TR><TD CLASS="quote">Hi all. I have a '92 Civic DX hatch with an H22a swap. Right now I have an EG SiR JDM gauge cluster, but I would like to install a '99-'00 Civic Si gauge cluster. My questions are:
Thanks
if your jdm gauge now works fine, then all you have to do is figure out what wires need to go on the ek gauge.. not very hard. if you do a search i knows theres a write up somewhere.
Thanks
Thanks</TD></TR></TABLE>
It has nothing to do with ecu and everything to do with in-dash wiring. Will it just swap in? No, The EG in-dash wiring needs to be rewired to the EK cluster plugs.
preludepower
Sep 5, 2005 02:17 PM
