FS: DOHC ZC parts, headers, ITR shocks, Neuspeed...
I have a few parts from my recently deceased 4 door to sell, so here they are. all prices are OBO unless otherwise noted.
ARP Headstuds for DOHC ZC: SOLD!!
DA integra rear sway bar with endlinks:
pretty self explanatory, also comes with bushings. $30+shipping
PM6 ecu:
this is a virgin(unchipped), working PM6 ecu. date stamp is 89.7.20
$70+shipping
JDM EF sidemarkers:
also pretty self explanatory, asking $30 shipped
Bilstein SP shocks for Integra Type R:
THESE ARE 4 DAYS USED! i put them on my car shortly before the "accident." i used them with Neuspeed Race springs and they were the best damping shocks i have ever felt with these springs. they retail for $115 each on http://www.eshocks.com; list for $175 each from bilstein.
I will be selling them as a package with the 88 civic lower control arms that i also got for them to fit. these also have 4 day old prothane bushings in them. the top hats for the rear will be included also, they have brand new upper bushings and metal collars in them.
$300 FIRM for the shocks, control arms with bushings, and top hats. this of course is plus shipping. I will include the Neuspeed Race springs for an extra $50.
SI transmission:
this will come with the shift linkage, i have installed a custom milled solid aluminum bushing in the tranny side of the stabilizer, and an Energy piece that mounts behind the shifter. had zero grinds when last driven. since i owned it, it was filled with Pennzoil Synchromesh fluid, changed at every third oil change.
$100+ shipping.
JG engine dynamics cam gears. SOLD!!!
DC sports header (4-2-1)for 88-89 Integra:
this requires NO modification to fit the dual cam ZC. the ports and primaries match up perfectly, only thing was that the down pipe came down at an angle towards the ground. this was taken care of and this header is ready to bolt on. has an extra o2 sensor bung welded in the merge pipe, but the stock oxygen sensor will reach from the stock wiring harness. has 3 small dents in two of the primaries.
$70 plus shipping
DOHC ZC cams:
stock cams, come with good cam seals. make offer.
anything from this pile you see, make an offer.
I will update this list as i get the engine disassembled. it is a DOHC ZC
I WILL NOT sell the intake manifold, as the fire was right beside it/on the throttle body. i was able to extinguish the fire before much damage was done, but everything that wasnt metal is pretty much toast. I will also not sell the head, just for the fact that i don not know how the heat affected it, and would not like to sell somebody a bunk head.
thanks for reading,
Parker
Modified by Sobe_Death at 8:19 PM 9/11/2005
PM6 ecu:
$70+shipping
JDM EF sidemarkers:
SI transmission:
$100+ shipping.
$70 plus shipping
DOHC ZC cams:
thanks for reading,
Parker
