stock b18a1 bore? 81.5mm je pistons fit without boring?
Old Sep 4, 2005 | 07:50 PM
slammedef06's Avatar
Default stock b18a1 bore? 81.5mm je pistons fit without boring?
what mm pistons go in a b18a1, will 81.5mm fit or do you have to bore it out?
Old Sep 4, 2005 | 08:46 PM
doood's Avatar
been there done that
Default Re: stock b18a1 bore? 81.5mm je pistons fit without boring? (slammedef06)
you will have to bore it .5
Old Mar 11, 2013 | 07:21 AM
egcoupekid's Avatar
stock bore size is 81.00mm
Old Apr 8, 2013 | 08:09 PM
99civ's Avatar
backwards question for future reference, can you run stock pistons if the block has been bored to 81.5?
Old Apr 8, 2013 | 08:15 PM
DeadlockRiff's Avatar
No, you need to get the 81.5mm pistons for the 81.5mm block.
Old Apr 8, 2013 | 09:16 PM
99civ's Avatar
Appreciate it.
Danial Gooch
Engine Machining & Assembly
Mar 20, 2018 08:40 PM
slammedef06
Sep 4, 2005 07:57 PM
delacampos
Dec 2, 2004 01:26 PM
turbo89civicb18hatch
Nov 8, 2004 04:42 PM
MisterB
Jan 15, 2002 11:26 AM
