FS: 38mm tial wastegate spring ::: small green .5bar 7.25psi $20
you can tell a big spring from a small spring by outside diameter...
if the outside diameter of the spring coil is under 2" (1.8" approx) its the small
if its bigger than 2" its the big spring...
http://tialsport.com/documents/w3_tial_38_sp.pdf
