Suspension & Brakes Theory, alignment, spring rates....
Is it possible to get better traction w/o lowering?
Old Sep 4, 2005 | 06:31 PM
JBARK's Avatar
Default Is it possible to get better traction w/o lowering?
I have a 1989 Honda CRX. I want to increase handling but I don't want to lower the Car. Is there a an aftermarket suspension out there that will do this? Thanks!
Old Sep 4, 2005 | 07:53 PM
PIC Performance's Avatar
Default Re: Is it possible to get better traction w/o lowering? (JBARK)
Better tires is a good start.
Old Sep 4, 2005 | 09:04 PM
G2 Speed's Avatar
Default Re: Is it possible to get better traction w/o lowering? (Noob4life)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Noob4life &raquo;</TD></TR><TR><TD CLASS="quote">Better tires is a good start.</TD></TR></TABLE>
bigger/lighter rims
good tires
Old Sep 5, 2005 | 02:15 PM
JBARK's Avatar
How about lowing the car slightly? Do I have any option then?? I have a downpipe that is a little big and I'm concerned about scraping.
Old Sep 5, 2005 | 04:30 PM
ohjolt2's Avatar
Stiffer springs are allways going to help you out, you could get coilovers or KONI/GC and only drop the car about an inch. Also look in to a rear ARB. Replace old bushings, bushings is a search all in its own.
Old Sep 5, 2005 | 05:03 PM
Default Re: (ohjolt2)
Yeah if you are now willing to lower the car, at least get some lowering springs. Lower = win! Too low = suck, though. Don't go wild.
Old Sep 5, 2005 | 05:16 PM
Tyson's Avatar
swaybars.
use a EF sedan front sway bar and aftermarket rear swaybar set. thats pretty much all i have, and some unknown jdm brand tires. i never feel unreasonably out of grip on the streets and highways.
lilpimpin705
Suspension & Brakes
16
Apr 22, 2008 06:32 PM
funtak
Oct 16, 2007 02:24 PM
Midori Green
24
Apr 28, 2007 10:54 PM
BrianCivicDX
11
Oct 16, 2006 07:05 AM
dan89crxsi
May 25, 2003 09:22 PM
