[FS]1991 Civic Si - B16a Turbo - Vid/Pics - 325 whp!!! (Tennessee) LOWERED PRICE!
Old Sep 4, 2005 | 04:28 PM
SiR Kid's Avatar
New User
Default [FS]1991 Civic Si - B16a Turbo - Vid/Pics - 325 whp!!! (Tennessee) LOWERED PRICE!
For Sale:
1991 Civic Si Black 5 speed w/ Sunroof 179~k miles. VIN will be Available on request for CarFacts.
Engine:
1989 Integra XSi B16a longblock
Purchased 6 years ago through a well known importer at the time.
Rebuilt 4 years ago with several upgrades:
Endyne/Wiseco pistons. .020 over, 9.2:1 compression, Ceramic coated tops for detonation protection, ceramic coated skirts for cylinder sleeve protection.
Total Seal Rings
Eagle H beam rods
STR Blockguard
All Genuine Honda bearings
Stock Crankshaft
ITR oil pump
Recently changed GSR water pump
Less than 8k miles on this shortblock
B16 head
GSR cams
ITR intake manifold
64mm JG Throttle Body
Venom Injection 550CC injectors
ECU
Z-Dyne SECU Gold fully programmable engine management w/ 3 bar MAP sensor and 2 step launch control (http://www.zdyne.com/)
IBM Laptop p1 166 w/ my custom fuel maps, ready to go, perfect for a "car" laptop.
B series custom turbo setup:
InlinePro cast stainless T3 manifold
Precision Turbo SC34 .63 hot/.57 cold T3/T4 turbo w/ piecut 90* elbow off outlet to clear stock radiator
Tial 35mm wastegate w/ elbot to clear hood
Greddy Type S BOV
Precision AS1025 31.50"L x 8.00"H x 3.50"D 600-Hp Intercooler
Custom piping powder coated titanium color.
Heavey duty couplers and t-bolt clamps on all connections
Custom 2.5" to 3" downpipe built to clear JimFab traction bars w/ HaSport welded mounts
Golden Eagle oil filter adapter for oil feed/pressure gauges.
-3 feed, -10 drainback
Extra's:
3" Thermal exhaust... A $550 exhaust system that's got about 5k miles on it.
Momo Monte Carlo steering wheel
Kenwood KDC7009
6.5" two way pioneers in the back
Boston Rally separates in the doors
Spare S1/A1 tranny
Extra seats(no brackets, just seats) to fix the normal driver side bolster wear with FACTORY cloth
Extra b17a block and crank (uber rare 92-93 GSR motor, crank makes for a great custom b16 stroker)
Blue anodized STR adjustable short shifter
CTR shift ****
Leather '00 GSR shift ****
'94-95 GSR cluster with harness to complete the cluster conversion
3.75" Autometer tach on the cluster bezel
GReddy Profec B Electronic Boost Controller (black)
GReddy Turbo Timer (black)
GReddy Oil Pressure Gauge (black bezel, white face)
GReddy Boost Pressure/Vacuum Gauge (black bezel, white face)
JDM SiR Spoiler (in garage) black, will match pretty close just being installed
7 (yes, seven) 15x6.5 Rota SubZero wheels in Steel Gray color. MINT. 4 w/ good Potenza S-03's, 2 w/ half life Nitto Drag Radials, 1 with a worn out S-03 as a full size spare w/ Kyotu(sp?) black security lugs
1993 integra rear disks (on car)
1990 Integra RS booster/MC/prop valve (needs to be installed)
Fully adjustable rear suspension w/ SPC lower control arms, toe and camber kits.
SPC front Adjustable Balljoints for camber correction
Neuspeed polished strut tower bar
Spare valve seals new in the bags from Acura.
Ground control coilovers w/ rear Tokico illumina 5 way adjustables. Front Tokico HP's in the front need to be replaced due to being blown from wheel hop over bad asphalt.
I'll give you every piece of Honda sh*t I own.
Seriously, too much to list.
Here's the video of the below dyno...
Dyno Video (Requires Quicktime) Right Click/Save as, please.
Car made 325whp/226wtq on the dyno two weeks ago in a 93 degree and 35% humidity dyno bay at 15 psi!!! This car is RUNNING STRONG and ready to go!
More pics of car, buildup and everything can be seen HERE
Car with intercooler installed: (piping on the driver side has been remade to clear now installed bumper)
http://home.midsouth.rr.com/sirkid/c...sioncorner.jpg
http://home.midsouth.rr.com/sirkid/civic/newpiping4.jpg
Car could use paint, but is straight with normal door dings for a 14-15 year old car. There is a couple of dents on the roof where the sunroof was pried out by theives. This can be cleaned up and fixed when painted without too much difficulty. Sunroof was replaced, has never leaked, and works perfectly without assistance. The car cleans up quite nicely as it sits.
WARNING: this is NOT a setup for a daily driver unless you are VERY dedicated. At the boost levels I am currently running, the car will lose traction all the way through second gear by simply rolling into the throttle, and third gear loses traction if you are not on good asphalt. This setup is good for 25+ psi in a full race application with only a sleeved block and larger injectors required.
$8k OBO.
Come and get it. Any decent entrepreneur could part it out for profit at this price, I just want to be rid of it. I can deliver the car just about anywhere in the country for the right price. I have truck and flatbed car trailer (NOT a dolly) available.
Old Sep 6, 2005 | 03:04 PM
SiR Kid's Avatar
New User
TTT
Old Sep 7, 2005 | 10:56 PM
SiR Kid's Avatar
New User
Bump for tonight.
Old Sep 9, 2005 | 08:34 PM
SiR Kid's Avatar
New User
Bump again
Old Sep 21, 2005 | 09:14 PM
SiR Kid's Avatar
New User
Car is SOLD.
Thanks for the purchase, SpeedingHatch. I hope you enjoy the car as much as I have.
Striker325
Jan 12, 2015 09:25 PM
irishflame27
Feb 22, 2009 08:21 PM
Panda Eg6
Northwest (Sales)
26
Sep 10, 2008 06:33 PM
SiR Kid
Sep 1, 2005 01:09 AM
