Antenna Q....
Old Sep 4, 2005 | 12:24 PM
bon3's Avatar
Default Antenna Q....
Hey
Can anyone figure this out? My Power Antenna does not work... it doesn't come up at all? What do you think it can be....
Old Sep 4, 2005 | 05:14 PM
P_Adams's Avatar
Default Re: Antenna Q.... (bon3)
Without knowing what year and model,
I'd say check the fuse.
Old Sep 4, 2005 | 07:45 PM
cottonfamily05's Avatar
Default Re: Antenna Q.... (P_Adams)
mine does not work either but guess I can blame the automatic car wash for that. lol
Old Sep 4, 2005 | 09:58 PM
Duane_in_Japan's Avatar
After checking the fuses, go near the antenna and have a freind turn on the radio and listen for antenna noise, if it makes noise, change it, if no noise then check the wires for a voltage change when radio is turned on and off, if there is a voltage change on one of the wires, sorry dont have a diagram for you, then radio is working and sending a command to the antenna, change it. No voltage change, check radio wiring or change radio.
Be carefull, does your model have any type of security or one of those new fangled radios that require a code to get it to work again after removal. Maybe the radio has two fuses on the back of it, did it work since you have owned it. Did you do anything to the system.
Old Sep 5, 2005 | 06:06 PM
bon3's Avatar
The car is an 91 honda accord lx...
there is no noise whatso ever.
Andrew LaRussa
Aug 8, 2015 03:13 PM
RiddimzCD5
Mar 3, 2012 03:46 AM
matthew91
Jan 28, 2012 04:16 PM
coolrace05
Nov 1, 2005 03:38 PM
geminis2k
Dec 1, 2003 10:53 PM
