lots of CRX and b16a parts for sale or trade....
IM me here or email me at mduryea1@unm.edu with questions or pics of any item. all stuff is OBD0! B16a from a JDM XSi Integra (unless specified otherwise)
PR3 OBD0 ecu-got with my swap and dont need-from hmotorsonline.com
4 PM5 ECU's
XSi B16a halfshaft
AEM Feul rail and matching FPR (blue)
STR throttle body (70mm i think)
b series lighweight flywheel (super light)
S1 Tranny-3rd grinds, but good for otherwise
Honda b16a timing belt-put on and pulled off to part out
b16a VTEC solenoid
b16a aleternator
b16a Power steering pump
b16a air conditioning condensor and fan
b16a intake manifold
b16a block
b16a crank
b16a cam plates
b16a stock header with o2 sensors
b16a complete wiring harness from an XSi
b16a power steering unit-complete minus hoses
b16a header heat sheild
b16a cam gears
b16a motor mounts from a DA Integra-XSi
b16a valve cover-Stripped
b16a obd0 distributor-brand new
crx climate control-small crack
crx radiator fan and condenser fan
crx washer bottle and lines
crx sunroof assembly (complete minus panel)
crx sunroof parts
crx power mirror switches
crx stock side mirrors (1990 Si)
crx door handles and key
EG Si glovebox minus handle
Civic VX centercaps-only have 3 of them
4gauge connectors to build grounding kits-4 ends per package including slip covers by lightning Audio
EG Haynes Manual and Original Civic Owners Manual
VSS-cable driven-JDM XSi
CRX headliner-Dyed black
CRX clutch cable
JDM Integra XSi shift linkage for b-series
JDM D-Power 17"wheels-new tires on front, 70 percent on rear
USDM Horn button for DA
willwood front pads-60 perc. left
all sensors on my b16a
brand new Valentine One V1.8 with 2 band pop.- bought for a roadtrip but didnt go.
energy suspension master bushing kitr for the 88/89 civic.crx-its incomplete but everything is new
heres what im looking for:
89 Teg front lip
ef8 maplight
2000 si front lip
16" GT3's, 16" C8's, Team Dynamics, and so on...just need some 16" wheels and tires that will clear willwoods (if ya got em)
full race CRX front cross-member
spoon obd0 vtec controller
carbon fiber or fiberglass plug
ef8 climate control plugs/harness
RSX Bose amp
EF8 power windows, EDM if possible
ef8 rear bumper
any other ef8/ef9 parts you have
IM me here or email me at mduryea1@unm.edu with questions or pics of any items
Modified by FakeJDMEF8 at 8:15 AM 9/5/2005
Modified by FakeJDMEF8 at 8:29 AM 9/6/2005
Modified by FakeJDMEF8 at 6:35 PM 9/14/2005
Modified by FakeJDMEF8 at 6:49 PM 9/14/2005
Modified by FakeJDMEF8 at 6:54 PM 9/14/2005
Modified by FakeJDMEF8 at 6:58 PM 9/14/2005
Modified by FakeJDMEF8 at 8:00 PM 9/14/2005
Modified by FakeJDMEF8 at 9:41 PM 9/18/2005
Modified by FakeJDMEF8 at 8:45 AM 9/24/2005
Modified by FakeJDMEF8 at 11:07 PM 9/25/2005
Modified by FakeJDMEF8 at 6:38 PM 9/26/2005
Modified by FakeJDMEF8 at 9:21 AM 9/28/2005
4 PM5 ECU's
XSi B16a halfshaft
b16a VTEC solenoid
b16a aleternator
b16a block
b16a crank
b16a cam plates
b16a cam gears
crx sunroof parts
CRX clutch cable
89 Teg front lip
ef8 maplight
2000 si front lip
RSX Bose amp
ef8 rear bumper
