civic transmission oil change
Old Sep 4, 2005 | 10:31 AM
EJ8 GSR-T's Avatar
Default civic transmission oil change
Hey im wonderin how to change the oil in my maual tranny....i did search but couldnt find anything, although im sure this question has been asked 1,000,000 times before
Old Sep 4, 2005 | 11:06 AM
bluebird's Avatar
Default Re: civic transmission oil change (userdead626)
look at the passenger side of your trans.. there are to removable bolts on it... the drain has a female entry for a 3/8 ratchet... remove the drain plug and drain oil into a pan.... above the drain bolt is a 17mm fill plug.. remove the 17mm fill plug and fill the the trans from the filler plug... ofcourse you should reinstall the drain plug before you fill the trans with o.e honda manual trans fluid or 5w30 motor oil... You will need a sump pump to pump the oil into the fill plug... fill until small amount of oil drips out of fill hole.. .re-install 17mm plug and go for a drive...
Old Sep 4, 2005 | 11:13 AM
nighttrain33's Avatar
Default Re: civic transmission oil change (bluebird)
You can just use a funnel and a hose to fill the trans up, but it is easier with 2 people. You can also fill through the VSS.
-Shane
Old Sep 4, 2005 | 11:27 AM
nocturnaldragon's Avatar
Default Re: civic transmission oil change (nighttrain33)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nighttrain33 &raquo;</TD></TR><TR><TD CLASS="quote">You can just use a funnel and a hose to fill the trans up, but it is easier with 2 people. You can also fill through the VSS.
-Shane</TD></TR></TABLE>
How would it be easier with two people? Ive allways open the fill hole and put it in the vss hole until it came out the fill hole, Stoped and put it all back toghter myself.
Im just curious on your methode.
Old Sep 4, 2005 | 11:28 AM
EJ8 GSR-T's Avatar
and how often should this be changed?
Old Sep 4, 2005 | 11:31 AM
philosofy1's Avatar
i usually change mine about every 12, 000mi.
be sure to o.e honda manual tranny fluid, its better than motor oil.
Old Sep 4, 2005 | 11:59 AM
Default Re: civic transmission oil change (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nocturnaldragon &raquo;</TD></TR><TR><TD CLASS="quote">
Im just curious on your methode.</TD></TR></TABLE>
I guess you're right, it's just cleaner that way. Getting the hose in there, hooking it up to the funnel, grabbing the trans fluid, taking the hose out without dripping all over the place, etc. It's just easier.
-Shane
FEAR6655
Feb 19, 2011 08:57 PM
killakoupe
Sep 15, 2006 09:16 PM
vics_si
Aug 4, 2005 04:47 PM
t0ekn3e
19
Mar 22, 2004 12:16 PM
Mires
Sep 21, 2002 08:16 AM
