SOHC ZC issues, need help guys
Old Sep 4, 2005 | 10:03 AM
Idiotboy's Avatar
Default SOHC ZC issues, need help guys
I swapped a SOCH ZC in my 90 CRX HF, It was throwing code 5, but I think I got that fixed because it doesnt show up anymore. But the car still idles really nasty, and after about 2 minutes it shuts down and dies. I have know Idea of whats wrong, I checked all the vacume lines and went over the motor several times but nothing I can see is visably wrong with it. If anyone can help that would be great. THanks
Old Sep 4, 2005 | 11:43 AM
dr_latino999's Avatar
Default Re: SOHC ZC issues, need help guys (Idiotboy)
Double checked all timing?
Old Sep 4, 2005 | 03:05 PM
turbodcivic510's Avatar
if your cel went away you need to reset it. theres a little black fuse boxunder the hood on the right side open it and take the main fuse for the batt. out or if theres one for the ecu... it is probably still throwing a code but not showing it
Old Sep 4, 2005 | 06:16 PM
Idiotboy's Avatar
Default Re: (g1_teg)
ok I'll try tomorrow
Old Sep 5, 2005 | 10:56 AM
Idiotboy's Avatar
Okay, still getting CODE 5, Im running a PM6 ECU with a JDM SOHC ZC, Ive checked all the vacume lines going to the map sensor and nothing is cracked or disconnected. Need some more info, thanks guys
zcsport
Jun 12, 2007 03:20 AM
mat18
Dec 23, 2006 11:26 AM
ludesrv
Feb 20, 2006 08:11 AM
Idiotboy
18
Sep 26, 2005 10:05 PM
HondaTomcat
Apr 8, 2005 11:32 AM
