Part list for FW+FD swap?
Old Feb 26, 2002 | 08:53 AM
Ideal R's Avatar
New User
Default Part list for FW+FD swap?
I "think" I saw it somewhere before but no luck with the search function (I spent half an hour searching it with various key words), so sorry if it is double posted.
I am going to do a FW and FD (JDM) swap. What parts do I need except the ones included in the JDM FD kit? A list of all the parts that I should buy from Acura and change it during the swap will be greatly appreciated. I don't want to wait a few days for a bolt from Acura after I tear the whole car apart.
Thanks in advance
Old Feb 26, 2002 | 08:56 AM
AssPenny's Avatar
Default Re: Part list for FW+FD swap? (Ideal R)
Don't know part numbers, I'm sure Mike K and help you out, but you will need:
High temp grease for the main shaft
The nut that goes on the end of the counter shaft
Tranny drain and fill washers
4quarts of MTF
Honda Bond
You don't realy need the nut that goes on the end of the counter shaft (we reused mine), but I would have replaced it if I could have gotten one in time.
Old Feb 26, 2002 | 08:57 AM
AssPenny's Avatar
Default Re: Part list for FW+FD swap? (AssPenny)
Oh yea, if you go after market flywheel, you will need 3 to 4 more of the bolts that hold the pressure plate to the flywheel. Grab them from a junk yard as they are like 3 bux a piece.
Old Feb 26, 2002 | 09:14 AM
D's Avatar
D
3 'needed' salvage yard, 4/$1
Old Feb 26, 2002 | 09:15 AM
Austin's Avatar
I love the little Notepad option...
From Japan you need...
98+ Integra R 4.785 Ring Gear
98+ Integra R 1st Gear
98+ Integra R Needle Bearing (2 required)
98+ Integra R Distance Collar
98+ Integra R Countershaft
and from USA you need...
97-00 Integra R [US] Upper Friction Damper 91211-P21-008
97-00 Integra R [US] Lower Friction Damper 91212-P21-008
Bond
Apr 12, 2005 07:42 AM
lee98lude
Mar 25, 2005 12:42 PM
wm5holla
Sep 24, 2003 09:45 AM
slow4thgen
Mar 17, 2003 08:39 PM
Unknown Member
Feb 24, 2003 12:23 PM
