What is the ideal offset on rims for ITR
Old Feb 26, 2002 | 08:38 AM
00ITR #543's Avatar
Default What is the ideal offset on rims for ITR
The car is dropped about 1.5". What is the ideal offset for 16s,17s and 18s?
Old Feb 26, 2002 | 08:39 AM
Big Phat R's Avatar
Default Re: What is the ideal offset on rims for ITR (00ITR #543)
ideal offset is stock: 50 mm
Old Feb 26, 2002 | 08:40 AM
FusionITR's Avatar
18's?!?!?
Old Feb 26, 2002 | 08:43 AM
AssPenny's Avatar
Default Re: What is the ideal offset on rims for ITR (FusionITR)
So 16" MF-10's, a 50mm off set would be good? How about the 43mm offset they sell also. If you are not happy with it you can put a 5mm spacer also.
Old Feb 26, 2002 | 08:59 AM
00ITR #543's Avatar
18's?!?!?
Yeah, just wondering. Rota makes 18" 5x114.3 rims now in 45 and 48mm offset. Really wanted to know for 16s.
Old Feb 26, 2002 | 09:05 AM
Big Phat R's Avatar
50mm offset 16" rim will fit a 225/40 ZR 16 tire (any wider and it will rub suspension) - although I have seen 225/50 Hoosiers on Type Rs with rolled fenders and spacer rings)
43mm offset 16" rim will fit a 215/45 ZR 16 tire (any wider and it will rub fender)
Old Feb 26, 2002 | 09:06 AM
DutchITR1689's Avatar
Default Re: What is the ideal offset on rims for ITR (fuzznuts)
http://www.tirerack.com/wheels/tech/offset.htm
http://home1.gte.net/macross/offsetFAQ.html
Datedda
Dec 11, 2007 09:00 AM
calde-da9
Sep 6, 2007 09:26 PM
Bastion
Dec 7, 2005 05:54 AM
MRDC2
Feb 21, 2003 05:33 PM
spettinger
Jun 18, 2002 04:55 AM
