vss sensor with obd1 conversion
Old Sep 3, 2005 | 07:19 PM
HELICALB16's Avatar
Default vss sensor with obd1 conversion
Im doing a obd1 conversion on my 90 crx do i have to wire in the electronic vss sensor for the vtec to work with my p28 ecu or can i stay with the cable vss
Old Sep 3, 2005 | 08:10 PM
PINEAPPLE's Avatar
Just use the vss off of your d series tranny. it drops right into the b tranny and uses the original cable.
Old Sep 3, 2005 | 08:46 PM
HELICALB16's Avatar
Default Re: (PINEAPPLE)
yes b series cable vss fits right in but will i still have vtec , dosen't the p28 ecu look for vss output to engage vtec
Old Sep 4, 2005 | 12:34 AM
airshifter's Avatar
Default Re: (HELICALB16)
your gauge cluster produces a vss signal for the ecu
obd0 vtec ecu's look for vss also
Old Sep 4, 2005 | 05:49 AM
HELICALB16's Avatar
Default Re: (airshifter)
THANK YOU FOR CLEARING THAT UP I SHOULD HAVE NO PROBLEMS THANKS
SolAssassin
May 7, 2009 10:00 AM
darknessgsr00
Sep 16, 2005 05:42 AM
toslowhatch
Nov 18, 2004 02:35 PM
drvfast
21
Nov 11, 2004 07:06 PM
temp
Feb 6, 2004 11:26 AM
