distributor difference?
Old Sep 3, 2005 | 03:22 PM
mycrx7's Avatar
Default distributor difference?
beside the way they bolt onto the head is a obd0 b16 dizzy internaly same as a obd0 ls dizzy?
Old Sep 3, 2005 | 03:26 PM
mycrx7's Avatar
Default Re: distributor difference? (mycrx7)
reason im asking is no check engine light, just put in the stock injectors and ecu so i could start it and run it for a bit but its running like ****, smokes all kinds fuel smoke when it revs up and will only go to 5500 or so. if a obd1 injector was installed instead of a obd0 one would it through a code?
Old Sep 3, 2005 | 06:09 PM
RCautoworks's Avatar
The injectors are different, so you have to keep obd0 injectors.
The distributors are the same way, you need an obd0 distributor. The ls one should work just fine on the b16.
Old Sep 4, 2005 | 12:12 PM
mycrx7's Avatar
Default Re: distributor difference? (90blackcrx)
i was using the b16 dizzy on the ls
fatbois88ef
Dec 4, 2011 02:23 PM
bhigh
Feb 13, 2009 07:01 PM
crxkidb16t
Oct 12, 2005 11:19 AM
nevin
Aug 14, 2003 07:02 PM
