Search is down... throwin code 6
I haven't driven my car all day i started it when i woke up but that was it then i turned it on a lil while ago cuz i need to goto work soon and the check engine light came on so i checked the codes and it was a code 6 ECT - Water Temp. Sensor.... where is that located? would it be safe to drive with that CEL on because thats my only way to work
I wouldnt drive with that code because you wont know if your over heating. Unless if you want to drive with the heater on full blast then sure.
The sensor is located under the dist. where the head meets the block. Its located on the head. Its a 2P wire.
mostwanted_ek
Apr 25, 2018 03:58 AM
rudyndrew
Dec 30, 2010 02:12 PM
93CharcoalHatch
20
Apr 20, 2006 05:42 AM
