where is the on a b16 IAT (Intake Air Temperature)flashing a 10 code
changed the stock manifold with a aebs and now is flashing a 10 code and checkengine. its still hits 8200 and has vtec. i thought when a check engine comes on it went into limp mode.but just need to know which one it is so i can check it out.
my car threw code 10 when the vtec solenoid was plugged into the coolant temp sensor. sometimes the code is wrong when the harness is pluged up stupid. good luck.
