Idle going up and down?
When car is out of gear ( Auto ) the idle surges between 600-1700 rpm. Also engine studders slightly between 1200-1800 rpm.
92 Accord EX AT 130,000 miles. All maintanance done.
Ant help would be great.
J
J
Have you cleaned the Throttle Body and Idle Air Control Valve of late? That's (those) the item(s) which controls idle / idle up speeds; we have to determine if it's (they) are just dirty, or if something else is effecting them.
P
P
You can use any commercially available carburetor cleaner for your cleaning purposes. (and it makes a great vacume leak detector as YeuEmMaiMai suggested (spray a light mist of carb cleaner near a vacume leak, and the rpms will rise.))
You won't need a Throttlebody (unless the butterfly shaft is worn in the bore and causes binding).
The Idle Air Control Valve I haven't seen aftermarket (perhaps someone else has run into one), But I'd go the OEM Honda <U>IF</U> you need one.
I use these folks:
http://www.hondaautomotivepart...cgry5=
P
I use these folks:
P
a loose inner valve in the fast idle valve will cause the same problem because it would create a vaccum leak, remove the top cover of fast idle valve 2 phillip screws, there is a black plastic valve inside with notches, use a screwdriver and see if u can tighten up the valve , do not overtighten it ,do it till it bottoms out
