New Rim offset
Old Sep 3, 2005 | 01:28 PM
FadeToBlack's Avatar
Default New Rim offset
I am looking to get some new rims on my 4th gen lude. I am choosing between some 15x7 rims with a 40+ offset or 16x7 with a 45+ offset. I would prefer the 15" rims, but the 16's have a offset closer to stock. I don't want to adversely affect my handling or stability, or do something that would put extra wear on my suspension. Are any of you 4th genners using rims with a 40+ offset and how did it affect your handling, twitchiness, or tendency to follow cracks in the pavement? What would you choose in this situation and is 40+ still a perfectly acceptable offset?
Thanks
Will
Old Sep 3, 2005 | 11:15 PM
JiGGaPiNNo's Avatar
Default Re: New Rim offset (FadeToBlack)
if i rememeber correctly i believe the 40 offset is going to stick out to far im running a 42 and its perfecton my 4th gen
Old Sep 4, 2005 | 03:57 PM
Default Re: New Rim offset (JiGGaPiNNo)
Did it make your car more willing to follow pavement imperfections and bumps? Also would 2mm of offset be the difference between perfection and too far?
Old Sep 4, 2005 | 09:48 PM
LudemanDan's Avatar
Remember, the offset is measured from the centerline of the rim, so when the rim is wider the offset you need to keep the wheel flush changes. Unfortunately I can't tell you what number you need.
You can't find any nice 15x7s with +45 offset?
Dan
Old Sep 5, 2005 | 12:40 PM
The majority of 15x7, or even 16x7s seem to all be 40+, though I'm sure I could special order some wheels. I am curious to know what offset people are using with their aftermarket wheels on their Ludes.
Old Sep 5, 2005 | 06:26 PM
yOnKiNaToR's Avatar
Default Re: (FadeToBlack)
i'm running 40 offset with 205's. i'm lowered 1.75f/1.5r with neuspeed sports and i don't even come close to rubbing. i could prolly run under 40+.
Old Sep 5, 2005 | 06:38 PM
Thanks a bunch, thats the info I was looking for. Anyone else out there running 40 offset?
Old Sep 5, 2005 | 09:49 PM
andre809_lude's Avatar
what about 5th gen... whats the max offset on that.... I seen a guy having 235/xx/R19 tires but dont know what rims they were...... and the wheels looked just right for that lude.
Old Sep 6, 2005 | 07:29 AM
mt23vtecbb2's Avatar
Default Re: New Rim offset (andre809_lude)
right now i have 16x7 with 225-45 with 40mm offset fits nice no rubs and it low!
Old Sep 6, 2005 | 05:38 PM
Hmmm the more I hear the more I am leaning toward the 15's w/ 40+ offset. My reason for going w/ the 15's has to do with the astounding amount of potholes and minor amount of dirt road (Rally Time! j/k) involved on my drive home. If you have ever been to Petrolia, CA, you know what I'm talking about.
Old Sep 6, 2005 | 06:03 PM
97Preludeguy's Avatar
16x7 with +40mm offset here, and it works absoutly perfect while looking sexy as hell. Im running on 205/50/16 BFG G-Force sports, which i also love too
EDIT: Im dropped 1.75 in the front and 1.5 in the rear on Neuspeed Sports and Tokico Illuminas
j.dizzle
Apr 10, 2007 01:33 PM
Silspeg6
Apr 2, 2007 05:41 PM
ludermark
Nov 30, 2004 01:11 PM
boostedhonda
Oct 17, 2003 01:51 AM
9d9GSR
May 21, 2002 12:53 PM
