need wheel stud
From: if you build it they will come, the bottom carolina, duh
my rim only has 2 suds holding the rim on. and i cant find any were on how to replace them. can someone please help.
thanks
thanks
1) Remove brake caliper
2) Remove rotor
3) Remove hub assembly
4) W/ a hydraulic press push the wheel bearing out
When you press the wheel bearing out most of the time it gets ruined so have a new one to put back in.
5) Press the wheel studs out and press new ones in
2) Remove rotor
