Huge problem during 5-Lug Conversion...Unable to remove this bolt.
I was following the instructions on how to do the conversion. Everything seems to be working great, but I finally got stumped on this two 14mm bolt. I spent over an hour trying to loosen these bolts. Is it even possible? Am I doin something wrong? or can it be that its just really rusted?
I am pointing at the 14mm bolt here... (This is the rear driver side)
Believe it or not? I Snapped the bolt so now its stuck. So i will have to bring it to a Shop to see if they can hammer it out or something.
I also have a question, what is this part that I circled in red called???
That would be your rear upper control arm. The bolt had probably seized inside the metal bushing sleeve, its a fairly common problem. If you experience it with other bolts, soak them in PB blaster/liquid wrench or some sort of penetrating oil to see if you can't break up some of that rust, and after they've soaked for a bit, apply some heat via a propane torch, thats what I used. Then its soak, heat, soak, heat, soak, heat, go at it with a breaker bar and steady force. I managed to free up 2 seized bolts that way. Then again, I snapped 2 bolts as well, hahahaha. Live and learn. During the re-install, use some anti-sieze on the very same bolts so you don't have this prob in the future.
Alright guys thanks for your comments!! I finally took car of the problem... The Bolt that broke off is pretty much done. I took it to a shop and had them try to remove the bolt but they couldn't do it so I bought a new rear upper control arm. Now everything is looking much better... All I have to say is, do this 5 lug conversion was a b*tch!! I don't think I would do it again lol...
Shocka1998LX
Aug 22, 2004 05:11 PM
