Rear Brakes: DA and CRX Si Rears the same?
Good to know, thanks man. I already have the DA front swap w/ master cylinder, brake booster and prop. valve, Do think I should install before I get the rear brakes (I know someone selling the Crx Si rears)? I'll be doing a motor swap in about a week, so I figured it be easier while I'm at it...But I don't want my stock rear drums to lock up everytime I brake hard. Should of made another post, just curious if you'd happened to know
Do the MC and BB before or during the motor swap, if you get a B-series it will be a bitch to do it after you do the swap.
Thanks, That's what I'd figured...easier install with less headaches, I'll go ahead and swap that out b4 I drop the ls in. Should I wait to put on the DA front brakes until I get the rear discs as well? Or just put the DA front brakes on while I'm the ls motor swap and leave the stock rear drums in the back?
