Need a wiring Diagram please.
Old Sep 2, 2005 | 06:52 PM
TommyBB's Avatar
Default Need a wiring Diagram please.
As you may know im putting in a DOHC ZC in my civic. they told me I would have to wire in a crank sensor and I have no clue what to do so please if you have any help full information please let me know. thanks Tom and I belive my car is OBD-0
Old Sep 2, 2005 | 08:44 PM
zCivic's Avatar
Default Re: Need a wiring Diagram please. (TommyBB)
is your car a HF, SI, STD or DX.
Thats the main point to start with
If SI or HF take the 2 blue wires that are in the original distributor plug which will be round and have 7 wires and extend them to the crank position sensor on the exhaust cam. ZC use an external crank position sensor.
If its a STD or DX you will need to run the wires straight from you ECU pins C1 and C2 because the ZC distributor uses the square 5 pin plug
http://hybrid2.honda-perf.org/tech/mattdx2zc.html
Old Sep 3, 2005 | 11:17 AM
TommyBB's Avatar
Its an Si and where are they located and how many are there?
Old Sep 3, 2005 | 12:23 PM
zCivic's Avatar
Default Re: (TommyBB)
There are 2 blue wires. One is blue/yellow other is blue/green. There both in the distributor round plug. Just cut those 2 wires and extend to the crank position sensor on the cam match them color for color.
Old Sep 3, 2005 | 12:51 PM
TommyBB's Avatar
And thats it nothing else?
Old Sep 3, 2005 | 01:12 PM
zCivic's Avatar
yup thats the only wiring difference seeing your already SI.
scooby2.0t
Sep 17, 2008 12:47 PM
4potnick
Nov 6, 2003 10:02 AM
BigDaddyRich
12
Sep 10, 2002 05:44 PM
l
Feb 19, 2002 09:00 AM
