b18a1 what do i need to put in a 1990 honda crx si
Old Sep 2, 2005 | 04:01 PM
hanseljohn's Avatar
Default b18a1 what do i need to put in a 1990 honda crx si
i know u guys are going to tell me to search but i have.. i have seen people with there problems and other thing but i dont see where anyone askes what all u need to do a swap in a 1990 honda crx si.. i have the engine what else will i need just wondering before i start the swap tommarow and need stuff thanks alot
Honda-tech
Old Sep 2, 2005 | 04:03 PM
UsDm_Junky's Avatar
you could have found that through searching, but i dont care you are here with the same common goal as me to make a honda fast so im not gunna shun you and tell you to search, i really could care less wether you searcher or not. Please tell me what engine and tranny and if you will be going all motor or boosting and ill do my best!
Old Sep 2, 2005 | 04:14 PM
hanseljohn's Avatar
Default Re: (UsDm_Junky)
i am looking to use my si tranny and i am wanting to turbo it and the engine will be a b18a1.. AM i going to need motor mounts also will i need a Ecu or can i use my Si one and not have to chane anything
Old Sep 2, 2005 | 05:13 PM
UsDm_Junky's Avatar
you will need to change the tranny to a b-series since you are going with the ls motor, you will need motor mounts and a shift linkage and the ecu i believe will have to be swapped
Old Sep 2, 2005 | 05:59 PM
g-ride-si's Avatar
yup all that plus some 90-93 integra axles(non abs) integra throttle cable, you can use your clutch cable, and thats about it.
Old Sep 2, 2005 | 06:07 PM
UsDm_Junky's Avatar
thanks g-ride for filling in lol i always forget something, or in this case a couple somethings lol
mo_thug_85
Mar 11, 2007 11:29 AM
boo72702
Jan 16, 2006 03:53 AM
Fred n J_v2.0
Nov 29, 2004 09:36 PM
mixmasterkeg
Mar 3, 2004 09:59 AM
NeonImpact
11
Sep 8, 2003 08:00 PM
