inverted tie rods
The only possible reason i can see for someone doing this is to compensate for an extremely lowered car.... however this is a BIG NO NO!!!!! The tie rod end id tapered... shaped sort of like a V. The steering knuckle is also shaped like a V. They fit together perfect. like this >> If you flip the tir rod over, you will change the fit.... like this <> not good... you could snap a tie rod.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaTechPro »</TD></TR><TR><TD CLASS="quote">The only possible reason i can see for someone doing this is to compensate for an extremely lowered car.... however this is a BIG NO NO!!!!! The tie rod end id tapered... shaped sort of like a V. The steering knuckle is also shaped like a V. They fit together perfect. like this >> If you flip the tir rod over, you will change the fit.... like this <> not good... you could snap a tie rod.</TD></TR></TABLE>
Is 100% correct. This should not be attempted without some serious machine work to invert the tapper
G2_Fella
Jun 25, 2009 01:44 AM
STPREZ
Jan 11, 2005 04:34 PM
