Can someone tell me where the fuel pump is on a 89 chvic hatch?
Old Sep 2, 2005 | 06:54 AM
dragracin247's Avatar
Default Can someone tell me where the fuel pump is on a 89 chvic hatch?
Can someone please tell me where the fuel pump is on this car? I have yet to look for it but my brother and I are argueing, he says its in the tank and i say its in the engine compartment... which is it?
Also, due to the fact I have to change it...
what is the easiest way??
Old Sep 2, 2005 | 06:57 AM
BiG Chris's Avatar
lift the rear seat coushin and youll see the access panel that leads to the gas tank and then you can change it. yes its in the tank
Old Sep 2, 2005 | 07:07 AM
gnar kill's Avatar
Default Re: (BiG Chris)
wrong that thing isn't the fuel pump that thing under your rear seat is for your fuel gauge.....you have have to drob your fuel tank out and the fuel pump is on the top of the rear....it isn't too hard....LMK if you got questions PM me
Old Sep 2, 2005 | 07:10 AM
BiG Chris's Avatar
well thats how it is in my crx
Old Sep 2, 2005 | 07:19 AM
Kryogen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BiG Chris &raquo;</TD></TR><TR><TD CLASS="quote">well thats how it is in my crx</TD></TR></TABLE>
No its not, That cover only leads to the Guage sending unit not the pump....I take it you have never even opened all that up before to see that it is not the pump like you imply it must be on your car and only your car is that way.
It must be a 1 off Honda made with the fuel pump under the cover in the rear and the sending unit where the pump should be. Its worth a fortune........
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragracin247 &raquo;</TD></TR><TR><TD CLASS="quote">Can someone please tell me where the fuel pump is on this car? I have yet to look for it but my brother and I are argueing, he says its in the tank and i say its in the engine compartment... which is it?
what is the easiest way??</TD></TR></TABLE>
Its in the tank, and the real only true way to change it was mentioned above drop the tank, but before you drop it unhook the sending unit under your rear seat.
Old Sep 2, 2005 | 07:22 AM
UNKNOWN_MEMBER's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BiG Chris &raquo;</TD></TR><TR><TD CLASS="quote">well thats how it is in my crx</TD></TR></TABLE> wrong information
Old Sep 2, 2005 | 07:23 AM
thanks guys for the quick responses! I am very mechanically inclined.. although i am from the darkside crossing over.. Domestic.. to you guys... I usually work on chevy's as that is what we race.. but i picked this car up as my daily driver because of gas prices...
anyways... could someone let me know about how long it will take to change? Do I need to drain the tank? Only bout 2 gallons in it...
Also, I am changing the pump do to the fact of what is happening, and I hope it is the pump... someone tell me im right please.. here is the situation...
The car will start, and run, its a manual... now when I start driving... at about 10mph in 1st gear it starts to hit like what seems to be a "rev limiter", but as you all know there is no limiter on here... In the past the car has done around 30 in first... in second it does the same thing at about 27, 40 in 3rd and in 4th gear can do about 60... please tell me i am right in my thinking of a fuel pump
Old Sep 2, 2005 | 07:29 AM
Kryogen's Avatar
when its at idle or the key is on the "on" position is the ECU light on? Sounds like this may be a ECU problem.
But it may be a fuel pump problem also, as I have never had to replace mine, Im not sure as to that symptom you described, but it *might* be related to low fuel pressure.
Old Sep 2, 2005 | 07:31 AM
Default Re: (Kryogen)
the service engine soon light is on and has been on for awhile... as the car has never had this problem til recently.. the the light has been on before
Old Sep 2, 2005 | 07:33 AM
mike-y's Avatar
Default Re: (dragracin247)
are you getting a check engine light at all?
a bad idle control valve can do something similar at low rpms but you can get past it if you keep your foot down. but if it absolutely won't rev higher than that, its probably not the idle/air valve.
Default Re: (mike-y)
yes the light is on... but when i keep it floored it WILL NOT go past that RPM
Old Sep 2, 2005 | 07:39 AM
Kryogen's Avatar
okay pull the passenger firewall carpet up and remove the 4 10mm nuts holding a shiny gold looking cover on.
Your ECU is located underneath, While its hooked up and the Key to the 'On" position or with the car running, watch how many blinks the ecu puts out. But this will only work while you have a check engine light.
It will blink consecutively so many times then pause then blink some more. If it repeats the same number of blinks after the pause you only have 1 code, but it may blink all kinda different numbers after the pause...make sure you write them down...how many blinks it is..
What kinda Civic you have DX or Si?
Modified by Kryogen at 11:51 AM 9/2/2005
Old Sep 2, 2005 | 07:40 AM
it is a DX
it says i am not allowed to post more then 5 messages in a 24 hour period... do you have an AOL instant messenger or something? I get off work in 2 hours.. so ill be doing it then..
Old Sep 2, 2005 | 07:41 AM
chadmasterc's Avatar
lift up the passenger floor carpeting and take a look at the light on the ecu. The light will blink a certain amount of times which will correspond to what code(s) it is throwing. if you do a quick search using the search button on the top right of the screen ( or the faq) you can find the key to what the codes are.
Old Sep 2, 2005 | 07:51 AM
Kryogen's Avatar
heres a good write up for checking.... http://www.hondaswap.com/forum...29806
Old Sep 2, 2005 | 08:15 AM
dragracing247's Avatar
thanks for all the help guys.. I will update the situation after the weekend.. I will check the codes today and get to work on it during my free time over the weekend... GREAT WEBSITE AND LOTS OF HELP! THANKS A LOT!
90 ef
Dec 2, 2009 05:33 PM
mars-EF-LS
Jan 1, 2008 09:59 AM
Vtec4me
Sep 13, 2007 12:01 AM
1990 CRX Si
Jan 9, 2006 05:08 AM
tilt
11
Nov 30, 2002 08:36 PM
