For Sale\Want to Buy: CRX Parts, 2 B18A1s & other things
Kind of new to selling parts to people in other states. Never really had to ship anything before and I do have Pay Pal, but still kind of new to using it. So bear with me
Pickup would be cool though!
Engine:
- 92-95 Civic AEM CAI (just piping, no filter or fittings or hose clamps) $50obo
- B18A1 full drop out $800obo includes: bottom end, head, intake and exhaust manifolds, distributor, alternator, fuel rail, injectors, throttle body, plugs and wires still in it, transmission, clutch, pressure plate, flywheel, axles, shiftlinkage, obdo LS ecu, wiring harness, I was told less thank 100K on this swap and long block. I've never run either engine.
- B18A1 long block, same as above minus drivetrain components, drivetrain and I think that's it... DOES have ECU and everything else I believe.. I'll update the information as much as possible for this longblock and the swap as soon as I can so there is NO CONFUSION on ANYTHING (just got done spending like THREE hours reading TWO scammer threads so I'm trying to make sure everything is AIR TIGHT!) $400obo
- 1 OBD1 LS ECU. I'm TOLD it has a Spoon Chip. I cannot verify beyond the Spoon logo on the chip. $175obo
- Civic\CRX B Series swap modified catalytic converter $25obo ( I passed Ohio ECheck with this cat and a B16A in a CRX)
- D16A6 Intake Manifold w\Throttle Body, TPS, Fuel Rail, Injectors (everything is there) Great for a Multi Point Conversion!
- I think it's a 1G DSM Intercooler, whatever it is in the picture on my ImageStation Parts slideshow.. Um like $20obo I guess? ****** DSMs..
Suspension:
- DC Sports Rear Upper Strut Tower Bar $100obo
- KYB AGX 4 Way Gas Adjustable Struts for 89-91 Civic\CRX w\Neupeed Springs $400obo
- CRX Si 14mm and 2 16mm rear sway bars $50obo each
- SPC Adjustable Ball Joints (front camber kit) $150obo
- Two stock donuts & I have the stock scissors jacks too...make offer?
Interior:
- 1988 CRX Si Steering Wheel (black) $10obo
- Rear Interior Side Walls (2 Sets) (black) $20 a piece (if condition is imperfect, I'll inform before anything happens and I'll lower the price! If I remember correctly, none of my stuff that's for sale is cracked... scratched at worse)
- 2 Rear Storage Compartments (black) (one's lid is detached, the other should be just fine) $20 for not so good one $75 for good one
- 2 Rear Vertical fold down walls (black) Neither are perfect but I believe both function just fine - $35obo
- Trunk Space Cover (I think 2) (black) $50obo
- Dashboard (no gauge cluster or bezel) (black) $50 (not the best condition from what I can remember, nothing should be cracked if I'm correct, I think just the metal framing around the climate control\stereo housing might be a little bent..)
- 89 CRX Si Carpet (black) $35obo, not greatest condition, will clean up very well though!
- 91 CRX Carpet (black) $50, MUCH better condition, a lot nicer on the eyes, I think JUST needs some vacuum love and should be near perfect!
- CRX Shifter console and boot (black) $15obo
Exterior:
- 91 Hatch w\wiper (black) $150
- 89 Hatch w\wiper (yellow) $150
- 91 DX Passenger Door (black) $100
- Primer grey CRX pass fender $30
D16A6 129Kish... ran before I pulled it, NO AXLES (they were shot, I was told they weren't
) I think it's time for a simple gasket kit and a scrubbing of the block. Otherwise, it runs fine from what I saw before I bought the parts car it came from. Has shiftlinkage, no ECU.. no wiring harness, all other things should be there. $400obo
Disassembled D16A6 w\217Kmi... I cleaned most of the block but this engine needs a rebuild, yet, the piston rings seem to be great?! Other than that, I'd PERSONALLY replace every gasket IMO, I kinda got lied to about the condition of the car it came in and the motor itself... tear downs ALWAYS tell the truth, **** SCAMMERS, May not come with tranny or shift linkage or ECU or wiring harness. Clutch and PP are shot..PP MAY be good with a resurface if you want it, I'd resurface the flywheel personally if you want it $275obo
See the pictures at http://www.imagestation.com/al...31225
Want to buy:
88-91 Civic\CRX E.S. Master Bushing Kit
88-91 Civic\CRX E.S. Engine Mount bushing kit (if it's not in the Master?)
D Series axles, non-hydraulic, boots in tact, NOT FUCKED UP
Full Race Traction bar (CRX)
D16Z6 COMPLETE swap
OR COMPLETE Head and ECU
CRX Front bumper with bumper lights and bumper support, drivers fender with corner light
91 CRX Si Rear Disc brake trailing arms, prop valve and master cylinder
Progress Group Coilovers
D series Quaife ATB LSD
CRX-VTEC tail lights
Any JDM\SiR pieces you have, lMK!
AIM works best = ExodusJKD or PM works well too.
Like I said, I just got done reading two Scammer threads and I'm not trying to deal with ANY bull-****. If I don't feel good about a transaction, I'll drop you without question. And also, like I said, I'm kinda new to shipping stuff. If it works out that I can't do it in a reasonable amount of time, or something comes up to the point where I feel like I can't hold up my end of the transaction without making myself look bad first, I'll inform you and just go to local pickup. Better a good reputation and no money in my pocket than cash+problems coming my way.
Thanks HT! Peace
Pickup would be cool though!Engine:
Suspension:
Interior:
Exterior:
) I think it's time for a simple gasket kit and a scrubbing of the block. Otherwise, it runs fine from what I saw before I bought the parts car it came from. Has shiftlinkage, no ECU.. no wiring harness, all other things should be there. $400oboDisassembled D16A6 w\217Kmi... I cleaned most of the block but this engine needs a rebuild, yet, the piston rings seem to be great?! Other than that, I'd PERSONALLY replace every gasket IMO, I kinda got lied to about the condition of the car it came in and the motor itself... tear downs ALWAYS tell the truth, **** SCAMMERS, May not come with tranny or shift linkage or ECU or wiring harness. Clutch and PP are shot..PP MAY be good with a resurface if you want it, I'd resurface the flywheel personally if you want it $275obo
Want to buy:
D16Z6 COMPLETE swap
OR COMPLETE Head and ECUCRX Front bumper with bumper lights and bumper support, drivers fender with corner light
Thanks HT! Peace
Oh yeah, I just got done stripping a parts CRX (it's y49 if you were wondering, yes it was wrecked, in the rear) so if you need any parts not listed, just ask and I'll let you know!
I have an integra rear disc brake conversion with cross drilled and slotted rotors which is a bolt in part just like a crx si brake conversion. I have a front bumper with lights and support. I also have a drivers side fender but without the light. All parts are in good condition. Will do $420 shipped. LMK and I'll try to email you some pics
TheCrimsonGhost666
Mid-Atlantic (Sales)
Aug 3, 2009 09:42 AM
civicmark
Aug 3, 2002 11:16 PM
back to top
