loose crx steering wheel
Old Sep 1, 2005 | 10:50 PM
stevescivic's Avatar
Default loose crx steering wheel
When I purchased my rex si a few years ago I recall the steering was very tight and that i had to wrench quite a bit to turn the wheel at slow parking speeds. Even when it was driving the steering was very tight but since I replaced the tires (195/60r14 vs the stock 185/65/r14) the steering feels as if its has play in it. The car steers fine and when I take it for wheel alignments at honda they don't ever say anything is wrong.
Why would changing my tires to a slightly wider track cause it to feel "loose"
Someone once said in a forum that replacing the end bushings or something like that would improve tightness of steering.
Thanks
Old Sep 2, 2005 | 10:39 AM
socalef9's Avatar
Default Re: loose crx steering wheel (stevescivic)
it could be that you have a lot of air in you tires, when i over inflate my tires my steering feels softer and easier to turn.
Old Sep 2, 2005 | 10:46 AM
Tyson's Avatar
rack end bushing and adjusting the steering rack gear box.
Old Sep 2, 2005 | 01:31 PM
teewhy55's Avatar
Default Re: loose crx steering wheel (Tyson)
i agree with tyson, try tightening the nut on the rack and pinion. that will eliminate any freeplay and replacing the rack end bushing helps for a tighter feel.
Old Sep 2, 2005 | 05:07 PM
are the rack end bushings hard to change?
How do I go about doing it?
Thanks
Jaynik
Nov 11, 2010 01:13 PM
^MikeG
May 23, 2006 08:40 AM
VTEC Visions
Suspension & Brakes
10
Jun 7, 2005 08:51 AM
Beat2Shit
Mar 21, 2004 05:23 AM
