will the jdm b16a axles fit in my 88 crx
Old Feb 25, 2002 | 09:48 PM
jdmDXrex's Avatar
Default will the jdm b16a axles fit in my 88 crx
hey guys i was wondering if some of you can help me out. will the stock axles from the 1st gen jdm b16's fit in my 88 crx dx? i know the 90-93 us integra axles fit if you remove the spacer but i thought i could save the money if i could use the ones that come with the motor. also im looking for the best prices on complete b16a changeovers and hasport or hcp mount kits (linkage optional).
Old Feb 26, 2002 | 12:36 AM
CRX-RX's Avatar
Default Re: will the jdm b16a axles fit in my 88 crx (jdm88crx)
The JDM axles will work the same as the 90-93 teg axles, if you get them. The only reason everyone buys teg axles is that JDM motors almost never come with axles.
Old Feb 26, 2002 | 09:20 AM
Kataku2K3's Avatar
Default Re: will the jdm b16a axles fit in my 88 crx (CRX-RX)
hey mikey what ya doin? Laterz
Old Feb 26, 2002 | 06:45 PM
StorminMatt's Avatar
The fitment of JDM axles depends on which car they are from. True SIR axles are a perfect fit. No removal of the sealing rings on the knuckles is required. And you won't have the length problems that 1990-1993 Integra axles often give. On the other hand, you will probably need to get a 1990-1993 Integra intermediate shaft. JDM Integra axles are actually the same as USDM 1990-1993 Integra axles. So they have all the fitment problems associated with these axles, including the need to remove the sealing rings on the hubs.
If by chance you get even the inner joints with cut shafts, consider yourself lucky. You can then go get a pair of 1986-1989 Integra axles and replace the inner joints on those axles with the JDM inner joints. You will then have true SIR axles! It does not matter which car these inner joints come from, as they are the same on the SIR and the Integra.
[Modified by StorminMatt, 3:47 AM 2/27/2002]
Old Feb 26, 2002 | 06:48 PM
EP3_05's Avatar
Default Re: will the jdm b16a axles fit in my 88 crx (StorminMatt)
Exactly, I got 90-93 axles with my S1 trans and I removed the ring in the hub and the dust seals, but the axles are too long still. I am now getting custom hybrid axles from http://www.raxles.com with new inner and outer joints and shafts.
turbodsm96
May 29, 2005 09:12 AM
Double_Clutchin
Apr 12, 2005 08:41 PM
mymeatb18"
Sep 18, 2004 01:48 PM
