is it hard to install adj cam gears?
is there any write up on how to install cam gears? the gears i have are JG cams gears, I want to install them cause the shop charges alot.. can you guys help.
Ray
Ray
It is theoretically easy, except I think all the gears that "fit" an H-series engine require cutting the covers. This can turn a 30-min job into all day. ymmv...
i wouldent really say its easy. I dont know about you guys but i friggin hate resetting the timing belt. Especially with the damn auto tensioner. That in itself is an all day project. Make sure your cam gears came with cam keys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raysjdmh22a »</TD></TR><TR><TD CLASS="quote">is there any write up on how to install cam gears? the gears i have are JG cams gears, I want to install them cause the shop charges alot.. can you guys help.
Ray</TD></TR></TABLE>
Here's a a quick how to guide. http://repo.jackmoves.com/album158
I think its on a B, but im sure the procedure is similar on the H
hope this helps
-B
hope this helps
-B
so all I have to do is put it at TDC and mark the tdc on the timing belt, and do a half turn on the tensor bolt to loosen the belt alittle, then loosen the bolt on the cam gear then use the stock cam gear mark with the new cam gear them reinstall the cam gear with the mark return the tensor bolt back to tight the belt and thats it right?
DumpedSi
Jul 28, 2003 07:26 PM
