Anyone with Spoon Calipers.....
Old Sep 1, 2005 | 06:02 PM
NAturalDC2's Avatar
Default Anyone with Spoon Calipers.....
can you help me with the topic, the brake pads are supposed to be from an ITR and the front pads have a metal clip on it, do i break that off? also do you remove the factory shim and put it on the spoon caliper? thanks for the info fellaz
Old Sep 1, 2005 | 06:31 PM
Im_In_There's Avatar
Default Re: Anyone with Spoon Calipers..... (NAturalDC2)
break those metal clips off and your good to go.
Old Sep 1, 2005 | 06:44 PM
yellow blur's Avatar
Default Re: Anyone with Spoon Calipers..... (Im_In_There)
You're going to have a problem with the tabs that are left from the metal squeal clips. You need to grind them down so the surface is flat with the rest of the pad.
Old Sep 2, 2005 | 05:13 AM
Black R's Avatar
25 Year Member
Default Re: Anyone with Spoon Calipers..... (yellow blur)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellow blur &raquo;</TD></TR><TR><TD CLASS="quote">You're going to have a problem with the tabs that are left from the metal squeal clips. You need to grind them down so the surface is flat with the rest of the pad.</TD></TR></TABLE>
I use a dremel cutting wheel to cut them off and grind them down flush.
Aftermarket pads - such as endless, etc don't come with the metal squeal clips.
Old Sep 2, 2005 | 04:23 PM
NAturalDC2's Avatar
Default Re: Anyone with Spoon Calipers..... (Black R)
well i got the Axxis pads i guess ill break them off, i was told from the guy i got them the same thing, can anyone also tell me if you reuse the factory shims? i think theyre called that, theyre little metal clips from the factory caliper that holds the pads in thanks
Old Sep 2, 2005 | 04:36 PM
JDM Factor's Avatar
No, take off all the clips you won't be needing them. And make SURE the washer that was supplied goes between the bracket and the caliper, not just on the end of the bolt. If not you'll have rubbing issues on the oustide pad.
Old Sep 3, 2005 | 01:07 AM
R you serious's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAturalDC2 &raquo;</TD></TR><TR><TD CLASS="quote">, theyre little metal clips from the factory caliper that holds the pads in thanks</TD></TR></TABLE>
i always thought the thousands of lbs of clamping force from the piston held the pad in
Old Sep 3, 2005 | 03:58 AM
swlabhot's Avatar
Default Re: Anyone with Spoon Calipers..... (R you serious)
Anybody experience serious pad knock with aftermarket pads and these calipers?? clonk-clonk-clonk... when braking &gt; releasing and going forward and reverse (ie parking..)
Old Sep 3, 2005 | 05:36 AM
Black R's Avatar
25 Year Member
Default Re: Anyone with Spoon Calipers..... (swlabhot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swlabhot &raquo;</TD></TR><TR><TD CLASS="quote">Anybody experience serious pad knock with aftermarket pads and these calipers?? clonk-clonk-clonk... when braking &gt; releasing and going forward and reverse (ie parking..)</TD></TR></TABLE>
none.
Old Sep 3, 2005 | 07:38 AM
JDM Factor's Avatar
I heard a lil noise when I had slotted rotors but now that I switched to blanks..none what so ever.
Modified by JDM Factor at 9:25 AM 9/4/2005
Old Sep 3, 2005 | 05:57 PM
NAturalDC2's Avatar
Default Re: (JDM Factor)
so you dont have to take anything off the factory caliper and put it on the spoon one? sorry for so many newb questions i just want to be sure thanks you guys
Old Sep 3, 2005 | 05:59 PM
thk's Avatar
thk
Members Only
Default Re: (NAturalDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAturalDC2 &raquo;</TD></TR><TR><TD CLASS="quote">so you dont have to take anything off the factory caliper and put it on the spoon one? sorry for so many newb questions i just want to be sure thanks you guys </TD></TR></TABLE>
Nope. You don't have to move anything from the factory caliper besides pads.
Old Sep 4, 2005 | 11:04 AM
swlabhot's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R &raquo;</TD></TR><TR><TD CLASS="quote">
none.
confused? I'm using Ferodo ds3000 as far as I remember and the pad is ever so slightly smaller than the space available on the spoon caliper hence the pad knock. hmmm maybe i should try some other pads...
Old Sep 10, 2005 | 04:56 PM
NAturalDC2's Avatar
how come the washer goes between the bracket and the caliper? i thought it goes after the bolt? thanks for helping me out
Old Sep 10, 2005 | 05:58 PM
JDM Factor's Avatar
the washer goes between the caliper and the bracket to shim the pads out so that they all have equal amount of room on each side. I got away with using the washer on the bolt before, but since I switched to new rotors and pads I can't do it anymore, the outside pad will just drag on the rotor. If you don't use the washer between the bracket and caliper your gonna run into problems.
Old Sep 11, 2005 | 11:21 AM
Mario's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAturalDC2 &raquo;</TD></TR><TR><TD CLASS="quote">how come the washer goes between the bracket and the caliper? i thought it goes after the bolt? thanks for helping me out</TD></TR></TABLE>
Try it out both ways, and see which way is the best way in getting your caliper in line/centered with the rotor. I used my washer just like a washer, and DID NOT put it in between the caliper and bracket. It was impossible for me to do it any other way.
I have AEM pads and it makes the same noises that you described, at the same situations too. Oh well, just gotta get used to it I guess.
Old Sep 11, 2005 | 12:01 PM
JDM Factor's Avatar
Like I said before, I had pad knock when I was running slotted, got annoying so I changed to blanks and don't have the prob anymore
Old Sep 11, 2005 | 05:07 PM
NAturalDC2's Avatar
well im using brembo slotted/cross drilled rotors.
Old Sep 11, 2005 | 05:52 PM
JDM Factor's Avatar
don't worry about pad knock, just turn the radio up and forget about it!
Old Sep 11, 2005 | 06:10 PM
Black R's Avatar
25 Year Member
Default Re: (Mario)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mario &raquo;</TD></TR><TR><TD CLASS="quote">Try it out both ways, and see which way is the best way in getting your caliper in line/centered with the rotor. I used my washer just like a washer, and DID NOT put it in between the caliper and bracket. It was impossible for me to do it any other way.
I have AEM pads and it makes the same noises that you described, at the same situations too. Oh well, just gotta get used to it I guess.</TD></TR></TABLE>
If you're using the itr specific spoon clappers, then you have to use the washer between the knuckle and the calipers to center them over the rotor.....
If you have a 5-lug swapped vehicle other than itr, or are using the EK9 specific spoon calipers, then you may not need to use the washer.....
In conclusion: do whatever it takes to center the calipers over the rotors.
Old Sep 12, 2005 | 01:13 AM
uNF$@#!'s Avatar
Default Re: (Black R)
hmm...i had to drill out a set of those metal squeel brackets from a set of pads before...i dont recall why...i just needed to.
It was a pain in the butt, but not all too difficult.
Old Sep 13, 2005 | 05:13 PM
NAturalDC2's Avatar
I got a 00 LS with the CTR 5lug
Old Sep 13, 2005 | 07:27 PM
JDM Factor's Avatar
Just run the washer between the caliper and bracket and call it day...you still haven't put those one yet!? This post has gone on for weeks!
Old Sep 13, 2005 | 07:40 PM
carblegal's Avatar
i get this from time to time. Not all the time though.
What (I THINK) I get is rattling from the pads. Anybody else experience this? I can really hear them rattle when I go over bumpy roads. (Azenis 215 on stock rims)
When parked, I can thump the front tire with my hand and hear the pads rattle. Is there a fix to the rattling or does nobody else notice it?
edit: I was told by private message to adjust the black tabs on the calipers. Could someone post a picture of them and exactly how to adjust them? I just dont understand.
Old Sep 13, 2005 | 07:56 PM
JDM Factor's Avatar
There's no adjustment... it's a slide in pad and wash your hands deal... Make sure you grind the tabs off of the back of the pads if they have them and slide them in... Hit Vtec and you won't hear the knock! Everyone says they have this issue but I don't have it anymore...I run blanks and don't have the problem.
