Balace Shaft Belt Tension - Help
I finally figured out how to set that damn belt... ( http://www.cybertrails.com/~pu....html ) <-- great link!
but i'm a little worried about the belt tension.. Do these belts usually run quite loose? Anyone have a deflection spec?
I use michel on demand - the diagrams are COMPLETELY wrong and they dont say anything about belt tension..
any help would be great.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2point2 »</TD></TR><TR><TD CLASS="quote">I finally figured out how to set that damn belt... ( http://www.cybertrails.com/~pu....html ) <-- great link!
any help would be great.</TD></TR></TABLE>
yeah I couldn't figure that out either so I cut the bastard off.
I just got it tight...It is suppose to self tension itself. But i always just push down on the tensioner to tighten it a little bit more then tighten the tensioner. I have never had a problem.
thanks guys.. i gave it a little help and tightened it down.
i'm a little paranoid because i cant get to the timing belt without pulling the motor out.
