throttle body question??????
i put a b20 throttlebody bored to 64mm and i put it on generally stock b16a and i turned the car on and it started right up but the idle was sitting at around 2500 and code 5,7,23 popped up i know what the codes mean but my question is ..is it to much air for my car ...also i am running a skunk2 manifild
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 »</TD></TR><TR><TD CLASS="quote">Adjust the throttle cable, make sure you used a new throttle body gasket, and hope you portmatched to the Intake Manifold to the throttle body.</TD></TR></TABLE>
No explanation why a throttle body would cause a knock sensor code. However, on the tps/map codes, is it possible you go the connectors swapped?
integrainside
10
Apr 29, 2008 11:50 AM
LSVTEC 91 Civic
15
Oct 28, 2005 06:16 PM
