which bushings to buy for ITR rear sway on EK?
Ive got an ITR rear sway bar (22mm) on my EK.
It's set up with 99 -00 Si endlinks, mounting brackets, d-brackets and bushings, which we drilled out to accept the larger sway bar.
I want to replace the drilled out stock rubber bushings with urethane bushings, but I dont know which ones to buy, and from whom I should get them.
does anyone make a set that fits within the 99-00 Si D-bracket (piece of metal that when viewed sideways looks like a "D" it has two bolt holes and keeps the bushing and sway bar planted to the mounting bracket), or will I have to get new ones?
Any recommendations?
Thanks for the quick response, bro!
So is that part number going to be
19-1108
or
88-7544 N?
And where did you order it from?
19-1108
or
88-7544 N?
I didn't order them. I've got this picture from the Type R swaybar install (on the 5G civic) in the http://www.hybridgarage.com archive. They use those exact parts to mount their 22mm rear bar to the subframe...
Here is the link:
http://hybrid2.honda-perf.org/tech/ITRon5G.html
Here is the link:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZoobeaR »</TD></TR><TR><TD CLASS="quote">Thanks for the quick response, bro!
19-1108
or
88-7544 N?
And where did you order it from?</TD></TR></TABLE>
Google is your friend! Summit has 19-1108's for $9.95
http://store.summitracing.com/...08-BL
19-1108
or
88-7544 N?
midwesta
Feb 13, 2007 09:36 PM
PhoBichNga
Feb 16, 2002 07:54 PM
