what ecu would you get for a .....?
Old Feb 25, 2002 | 08:00 PM
ahybridcar's Avatar
Default what ecu would you get for a .....?
Got a b16a im goin all motor on and trying to decide which ecu to go with. Engine will have built head before anything and aggressive cams are a option in the near future. What do you all recommend?
Old Feb 25, 2002 | 08:08 PM
rainforest's Avatar
Default Re: what ecu would you get for a .....? (ahybridcar)
get a dyno run and see what you need first but if all else fails skunk2 chip is big right now. run pretty rich but if you have the cams,comp to back it up its good. lcr for a slightly build motor would be the other choice.
Old Feb 25, 2002 | 09:20 PM
ahybridcar's Avatar
For now im gonna run either skunk2 stage 1 or ITR cams and valvetrain with basic bolt-ons. I just need a better ecu than the si one that will be cheap to adapt and raise the redline.
Old Feb 25, 2002 | 09:50 PM
IMPORTdrag's Avatar
93 gsr (p61) ecu is the best. it makes the most hp hands down on the dyno. just raise or remove the rev limiter
http://www.jgenginedynamics.com
esohsee
Dec 7, 2005 10:07 AM
pawz1200
Feb 23, 2005 05:20 AM
AK94GSR
May 28, 2003 02:01 PM
Audipwr1
Oct 16, 2002 08:38 AM
JDM_GSR_131
Sep 19, 2002 05:37 PM
