Running extremely rich, how to trick the ECU to get it run leaner?
D16A9 - DOHC ZC engine, PM7 ECU.
After installing ITBs and Crespo Stage 5 camshafts, my car runs extremely rich. I know that this is normal. The point is that i'd like to get it to the tuner that is located 80miles from where i live. Are there any tricks to make it run a bit leaner?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast88std »</TD></TR><TR><TD CLASS="quote">If you got all that good stuff on the car, why just not turn down the fuel pressure?</TD></TR></TABLE>
Haven't bought adjustable FPR yet
Any trick with sensors?
you could possibly trick the coolant temp sensor into thinking the car is running 190 -200 degrees with a resistor. I know that is a trick used with colder temps to make the ecu dump more fuel, so maybe with hotter temps it will dump less fuel. you will have to research a bit exactly how to do it though. Just an idea.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16dcoe45 »</TD></TR><TR><TD CLASS="quote">you could possibly trick the coolant temp sensor into thinking the car is running 190 -200 degrees with a resistor. I know that is a trick used with colder temps to make the ecu dump more fuel, so maybe with hotter temps it will dump less fuel. you will have to research a bit exactly how to do it though. Just an idea.</TD></TR></TABLE>
not the coolant sensor...the IAT sensor....and im pretty sure all that will cause is the timing to be retarded...
one way would be to put a variable resistor inbetween the map sensor and ecu...if the ecu thinks there is less air coming in it should cut back fuel
i have a similar problem. but i do have a regulator n it's set at about 45/48. is that high, cause i have shitty gas milage. d16z6 W/zex 59300 cam, i/h/e. kms valvetrain. i do have a 6 puck sprung clutch too but i dont think that would affect the gas. any help would be good. thanks
CivicRaping
May 4, 2005 11:52 PM
