need a few b16 answers
Old Aug 31, 2005 | 11:31 PM
Donkey85's Avatar
Default need a few b16 answers
okay i'm swapping in a b16 into a 90 std hatch. first question is what cold air intake do i get to fit? also will a header for a 92 integra gsr bolt on and fit with no problem??
Old Aug 31, 2005 | 11:38 PM
TH33G4MON3's Avatar
Default Re: need a few b16 answers (Donkey85)
what b16?
Old Aug 31, 2005 | 11:47 PM
Donkey85's Avatar
Default Re: need a few b16 answers (TH33G4MON3)
its a JDM b16a odb0
Old Sep 1, 2005 | 09:37 AM
Donkey85's Avatar
my bad the header is for 94-95 gsr will it still fit my b16a. come on you guys somebody has to know
Old Sep 1, 2005 | 10:01 AM
Malgerus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Donkey85 &raquo;</TD></TR><TR><TD CLASS="quote">my bad the header is for 94-95 gsr will it still fit my b16a. come on you guys somebody has to know</TD></TR></TABLE>
It will bolt up, it will just hang a bit low and you won't be able to use the bracket that sits behind the oil pan.
Old Sep 1, 2005 | 10:05 AM
SiR Inspired ED7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Donkey85 &raquo;</TD></TR><TR><TD CLASS="quote">my bad the header is for 94-95 gsr will it still fit my b16a. come on you guys somebody has to know</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. S &raquo;</TD></TR><TR><TD CLASS="quote">
It will bolt up, it will just hang a bit low and you won't be able to use the bracket that sits behind the oil pan.</TD></TR></TABLE>
Yes, they will fit as the ports are the same size/location on the B series engines. However, the flange that connects to the cat may be differently shaped and the header for a B18 (especially the ITR) will be longer than a B16 - as in you will lose more ground clearance.
Old Sep 1, 2005 | 10:12 AM
Adam.C's Avatar
for the intake you can just use an intake for a 90 si hatch or AEM makes hybrid intakes but that is just a waste IMO. For the header should bolt up but there could be clearance issues.
Old Sep 1, 2005 | 10:31 AM
Malgerus's Avatar
Default Re: need a few b16 answers (88 Crx Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88 Crx Si &raquo;</TD></TR><TR><TD CLASS="quote">
Correct, I should have mentioned that. It wasn't a problem for me since I'm running a test pipe that has a swivelling flange on it
Old Sep 1, 2005 | 11:05 AM
Suck my DX's Avatar
Default Re: need a few b16 answers (Mr. S)
well whatever cai u decide to go with ...make sure that it is 3 in. diameter
Old Sep 1, 2005 | 11:38 AM
Malgerus's Avatar
Default Re: need a few b16 answers (Suck my DX)
AEM CRX Si is only 2.5 inches. I have a 3" SRI that clears my battery easily, and if I felt like it I could turn it into a CAI pretty easily. I think it's just a cheap ebay intake but I have a nice big K&N that I put on it.
Old Sep 1, 2005 | 12:53 PM
Suck my DX's Avatar
well as far as intakes go i will never buy a quality one since they are all the same...**** i made my last cai out of exhaust piping
NINE TRE
10
Mar 22, 2006 04:16 PM
TylerC
Aug 21, 2005 09:01 PM
SiR Inspired ED7
Jun 15, 2005 10:34 PM
WREKONIZE V8 KLR
Jan 2, 2005 08:58 PM
SamC
Jan 8, 2004 12:19 PM
