spark plug has water on it...
Old Feb 25, 2002 | 07:01 PM
CLICC916's Avatar
Default spark plug has water on it...
the other day i was just doing a routine checkup and i noticed there was water (or some kinda liquid) in the chamber where the spark plug wire connects to the spark plug...it mustve gotten in there when i was washing my car, i don't have a busted head gasket (i think). anyway, my car is running kinda funny, i can sorta feel the fuel (or spark) cut out when i'm cruising at normal speeds...would this be due to my spark plugs and/or spark plug wires? if so, what brand should i get? i have a b16a
Old Feb 25, 2002 | 07:24 PM
Raz1983's Avatar
Default Re: spark plug has water on it... (CLICC916)
I would get the NGK Iridiums. they are good quality and it will create more hp/torque than normal plugs. Atleast for me, i felt a lot more strength on the high-end. I also did some ground wiring, if htat helps any.
Old Feb 25, 2002 | 07:37 PM
AfEn808's Avatar
New User
Default Re: spark plug has water on it... (Raz1983)
maybe your head has a small crack letting coolant leak into your plug area from the coolant passages cause I dont think by washing your car you could get water into the spark plug area.
Old Feb 25, 2002 | 07:45 PM
CLICC916's Avatar
Default Re: spark plug has water on it... (AfEn808)
well, it was washed under the hood too, supposedly. i just got my car painted and i think they washed underneath the hood to paint the hood....
Silver_lude
Mar 15, 2007 12:39 PM
Zaakro
Feb 1, 2007 11:29 AM
JoHA
Apr 6, 2006 01:53 PM
mickey513
Jan 29, 2003 06:43 PM
FitCRX
Jun 13, 2002 10:22 PM
