HELP!!!! My rear lights wont go off
help guys please....my rear brake lights will not go off, even when i turn my car off. it just started to this the other day.
anybody have any clue what the problem is. also, could anyone give me any info on how i can fix the problem. as of right now i am just undoing the negative battery teminal when i get out of the car.
please help guys this is getting real annoying
did u do any work on the brake system?
check the clearance for the brake booster to master cylinder. this happened to me when i installed a new brake booster. and actually since the clearance wasnt right, it was slowly locking up my brakes.
after i set the clearance right (had to rig it up using washers in between the master and booster), I had to disconnect the sensor, adjust it, and then plug it back in.
Then I was good to go
Sounds like a broken brake light switch. I had the same problem on my hatch a while back - it's a plastic switch that can break. There is a slot in the brake pedal lever that the switch attaches to. You can stick a bolt in that slot and it will push the plunger switch up to turn off the lights. Sounds complicated, but if you look up underneath the dash it should make sense.
so the switch is on the actual brake pedal correct...going to look at it in the morning. btw mugenmike by sticking the bold in the slot will it fix the problem or will i have to go to acura and buy the part???
How the hell is this type R related? It seems you have a integra LS? Your in the wrong forum. Go buy a new switch and stop your crying you little girl....If you are in the miami area, make sure you go to DR technologies....they have great prices.
Make sure you stay away from Happy do racing.....they are a rip off
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stRtypR25 »</TD></TR><TR><TD CLASS="quote">so the switch is on the actual brake pedal correct...going to look at it in the morning. btw mugenmike by sticking the bold in the slot will it fix the problem or will i have to go to acura and buy the part???</TD></TR></TABLE>
The switch actually runs through the brake light lever. If the bottom of it breaks off, the plunger portion of the switch will poke right throught eh slot in the brake pedal lever. I stuck a bolt in the slot, and it worked for the remainder of the time I owned the car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stRtypR25 »</TD></TR><TR><TD CLASS="quote">thanks mugenmike....i just dont understand one thing. when u say brake pedal lever, you are referring to the actual brake pedal right???</TD></TR></TABLE>
No he is refering to your e brake you *** clown....BUY THE SWITCH
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rsx veilside »</TD></TR><TR><TD CLASS="quote">go to acura and by the part u cheap *** </TD></TR></TABLE>
How can he buy the part if he doesn't know what's wrong? Go flame somewhere else, asshat.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ultimatehonda »</TD></TR><TR><TD CLASS="quote">How the hell is this type R related? It seems you have a integra LS? Your in the wrong forum. Go buy a new switch and stop your crying you little girl </TD></TR></TABLE>
How about you stop being an e-*******? If you can't offer any help, just STFU and move to the next thread.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugen Mike »</TD></TR><TR><TD CLASS="quote">
How about you stop being an e-*******? If you can't offer any help, just STFU and move to the next thread.</TD></TR></TABLE>
Its Ok We can be Eassholes....We know this guy....He fcked up both are trannys somehow....we still consider him a friend....he is the *** hat...lol
hey ultimate noob....he is def. not referring to the e-brake u tard. btw is ur civic break into the 19 sec. yet?? i would rather want input from someone who knows their stuff about cars, so mugenmike or anyone else BUT ultimatenoob answer my question
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stRtypR25 »</TD></TR><TR><TD CLASS="quote">hey ultimate noob....he is def. not referring to the e-brake u tard. btw is ur civic break into the 19 sec. yet?? i would rather want input from someone who knows their stuff about cars, so mugenmike or anyone else BUT ultimatenoob answer my question</TD></TR></TABLE>
Your right I dont want to be reponsible for ur sled breaking down....take it to Happy do racing....Also how is the type r 225 selling? Did u sell the stickers yet??
As far as I'm concerned, you're the only asshat here. Appears you have an EM1 from you avatar - maybe YOU need to go to a different forum.
NOt the pedal, but the lever that the pedal is attached to. Get underneath the dash and take a look, it will make more sense that way.
</TD></TR></TABLE>As far as I'm concerned, you're the only asshat here. Appears you have an EM1 from you avatar - maybe YOU need to go to a different forum.
Simmer down Coco....it was a joke.......
88crxhfb16
11
Jul 28, 2005 08:07 PM
chito_zan
13
Aug 9, 2004 11:06 AM
