reducing intake heat soak and noise
swapped out aem for comptech icebox long time ago as wanted somethim quieter which it is but now wanna reduce noise even more while keepin it on and wouldnt mine reducing heat soak BUT wanna do it ghetto style/cheap
so anyone any suggestions?
i know you can buy heat reflective tape but its dam expensive so was thinkin stickin some tin foil around whole intake and then puttin some of this sound deadining over that. good/bad/stupid idea ?
the foam is fire retardent and told its fine to used in engine bay
How about putting the stock intake box back on, selling your comptech ice box and putting a drop in K&N filter. Better flow and quiet as hell
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Radical_Edward »</TD></TR><TR><TD CLASS="quote">Order a NextGear Thermoshield intake manifold gasket from Nipponpower.com
i already have a hondata gasket
</TD></TR></TABLE>i already have a hondata gasket
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vti444 »</TD></TR><TR><TD CLASS="quote">
i already have a hondata gasket </TD></TR></TABLE>
Yeah and you are still having problems? The Nextgear gasket is way better
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Radical_Edward »</TD></TR><TR><TD CLASS="quote">Are you talking about the intake moving and making noise? Also, What type of intake is it?</TD></TR></TABLE>
its comptech icebox, no its not moving, just wanna reduce overall noise (resonance etc) you get from aftermarket intakes when driving
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vti444 »</TD></TR><TR><TD CLASS="quote">im more arsed about reducing noise than heat soak (aint severe but would be nice to do somethin cheap that helps reduce it)</TD></TR></TABLE>
Wrapping the tube isn't going to reduce much noise.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vti444 »</TD></TR><TR><TD CLASS="quote">so theres no material that is gonna help me ?</TD></TR></TABLE>
Not to wrap around the tube to make it quieter. Heat reflection, sure, but not noise reduction.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igo4bmx »</TD></TR><TR><TD CLASS="quote">u are experiencing heatsoak?
i always thought my engine bay was hot until i boosted my motor and now know what heatsoaking is
Seriously. No AC+Turbo+Shoes= Can barely drive because the floorboards are so hot.
I'm thinking of trying that ghetto "Washer under the hood" trick, but put them between the frame and mount instead of the mount and hood.
</TD></TR></TABLE>Seriously. No AC+Turbo+Shoes= Can barely drive because the floorboards are so hot.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vti444 »</TD></TR><TR><TD CLASS="quote">i think i can use the oem itr intake arm, the box and pipe that feeds it is plastic while arm is metal. will have a look when im in scrapyard next</TD></TR></TABLE>
It's probably going to stay loud unless you can put something like the stock resinators on it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nota-eg »</TD></TR><TR><TD CLASS="quote">Seriously. No AC+Turbo+Shoes= Can barely drive because the floorboards are so hot.
I'm thinking of trying that ghetto "Washer under the hood" trick, but put them between the frame and mount instead of the mount and hood.</TD></TR></TABLE>
same here
im gonna get my manifold and downpipe and turbo and dumptube all ceramice coated
same here
It's probably going to stay loud unless you can put something like the stock resinators on it.</TD></TR></TABLE>
Yeah, even if you just had the stock intake arm and box with the resonator removed, it is still loud.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AutoXer »</TD></TR><TR><TD CLASS="quote">Yeah, even if you just had the stock intake arm and box with the resonator removed, it is still loud. </TD></TR></TABLE>
Mine was louder with stock intake arm and stock airbox/filter than when I did my homemade-CAI
mikzsan
Acura TSX
Jul 15, 2018 01:43 PM
yuning83
Honda Civic (2006 - 2015)
28
Jul 21, 2007 03:57 AM
CRexcellence
Sep 13, 2002 08:19 AM
