B16A into 90 Teg
Old Feb 25, 2002 | 06:22 PM
Lynx's Avatar
Default B16A into 90 Teg
I would like to put a B16a into my '90 4 dr Integra. Since this is going to be the first time I have ever swapped an engine, I am uncertain about one thing. I would appreciate as much detailed information as possible.
1. How much modification (if any) to the wiring harness is necessary? Obviously, I have to do some in order for the VTEC ingagement, but how entailed is it? The mechanical stuff doesn't bother me, it's the electrical.
Remember, I'm a virgin....
with the engine swaps that is.
Old Feb 25, 2002 | 06:27 PM
EP3_05's Avatar
Default Re: B16A into 90 Teg (Lynx)
You will have to run four extra wires.
VTEC solenoid
VTEC pressure sensor
Secondary O2 sensor
Knock Sensor
It is not really that involved. Run the four wires to the ecu and to the sesnors and you are done. everything else should be plug and play.
Old Feb 26, 2002 | 07:48 AM
DR. ON POINT's Avatar
Banned
Default Re: B16A into 90 Teg (91civic)
thats one of the simpleset swaps u can do...good luck and have fun
Old Feb 26, 2002 | 11:44 AM
Lynx's Avatar
Default Re: B16A into 90 Teg (On Point EK)
Thanks for the help boys. Appreciate it. Glad to hear it is simple, cause my Integra has an immaculate body, but the engine has 157,000+. I have a long wait in store for the Evo, so I figure an engine swap for my beater is appropriate.
Old Feb 27, 2002 | 04:48 PM
Hayate42's Avatar
you should check out http://www.g2ic.com about 30 people there have done the same swap. Also if you go to the "teg tips" section they have a detailed report of what is needed to put any B series into our cars. Good luck with swap. I just ordered at B16 for my car.
Good luck,
Dan
aojtin
May 16, 2008 10:44 PM
90civicSiRacer
Oct 1, 2007 02:36 PM
Zatzy
Jul 9, 2005 03:51 PM
suncoastcustoms
Jul 19, 2004 04:08 AM
civic_sir94
Dec 18, 2002 07:43 AM
