Engine Stand Question
Old Aug 31, 2005 | 07:35 AM
MyRex's Avatar
Default Engine Stand Question
I'm going to start working on the DOHC ZC engine that I've had sitting for a little while. I borrowed an engine stand and I understand there are four bolts that go from the engine stand and bolt to the bell housing area of the engine. My concern is since the block on the engine is aluminum will the stress from these 4 bolts holding the engine cause damage to the block? I know people use these things all the time on larger (V6, V8) engines with cast iron blocks. This is my first time using an engine stand on an aluminum block engine. Just looking for some feedback. Thanks!
Old Aug 31, 2005 | 10:28 AM
IHateJDM's Avatar
Default Re: Engine Stand Question (MyRex)
My h sat on an engine stand for 5 months before I put it in (and only 3 of the mounting bolts lined up). You'll be fine.
Old Aug 31, 2005 | 11:16 AM
MyRex's Avatar
Default Re: Engine Stand Question (IHateJDM)
Thanks. Any idea what size and tread those bolts are you used?
Old Aug 31, 2005 | 11:21 AM
IHateJDM's Avatar
they were tranny bolts, off hand I don't know the size and pitch.
Spawne32
Mar 6, 2010 11:06 AM
Anthrax-VX
May 25, 2004 11:35 AM
Anthrax-VX
Apr 24, 2004 05:43 PM
Gonzo_SiR
Nov 3, 2003 07:03 PM
