► FAQ: How to paint your wheels
Old Oct 25, 2002 | 11:48 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default How-to: painting wheels
Originally Posted by doubleshotz
Since this topic has been popping up a lot lately, I decided to write up on painting wheels I did for my winter wheels.
Everything I used can be found in your local automotive parts store.
<U>Materials</U>
· Paint stripper + brush (that withstands the stripper)
· Wire brush
· Sandpaper (120-2000grit)
· Scuff pad
· Primer (optional)
· Paint
· Clearcoat
· Gloves
· Masking tape
· Blue shop towel
· Tack cloth
· Acetone
· Sanding Mask
· Spray can gun adapter (optional)
· Beer (optional)
· TIME AND PATIENCE
Some materials are not pictured
Wheel (OEM Integra)
Paint stripper (BIG container, not spray can)
<FONT COLOR="RED">READ THE INSTRUCTIONS ON PAINT STRIPPER BEFORE USE</FONT>
<U>Step One: Strip</U>
Removing existing paint and clearcoat on wheel
<FONT COLOR="RED">PROTECT EYES AND SKIN FROM PAINT STRIPPER AT ALL TIMES</FONT>
1. Pour the paint stripper in a metal can (I used a soup can). Dip the brush in can.
Start applying the stripper slowly with brush. DO NOT RUSH THIS STEP
2. The paint and clearcoat should start bubbling up shortly.
3. Set a timer to 20 minutes.
4. While you wait......
<U>Step Two: Scrub</U>
Scrubbing off paint and clearcoat. This will ensure you not to repeat step one.
1. Grab a wire brush (I used stainless steel)
2. Start scrubbing. Watch your eyes!!
3. Pressure wash off the remaining residue and air dry.
<U>Step Three: Sand</U>
Sanding down area that you wish to polish. Skip this step if you do not wish to polish.
1. Dry sand starting with 120 or 180grit if you have deep scratches and/or curb marks. If there is no damage start from 220grit. Work your way up to 320, 400, 600.
Here's how it looks after 120-400 (I sanded the lip only)
2. Wet sand starting with 600grit working up to 800, 1000, 1500, 2000. Use lots of water.
After wet sanding...
<U>Step Four: Prep</U>
Masking down area that will not be painted and scuffing.
1. Mask the area you polished and/or you do not wish to paint by using masking tape (I used green and blue, both by 3M)
2. Scuff down the area that will be painted with a scuffing pad. Take your time and make sure surface looks even.
3. Slightly wet 1/8 of a blue shop towel with acetone and start wiping down the scuffed area. Finally, wipe down with tack cloth to get every last piece of lint the towel left off.
<U>Step Five: Primer</U>
Spraying primer(optional). If you do not wish to use primer you may skip to the next step. You can use sandable primer, primer sealer, etc...
1. Make sure all surroundings are covered/masked unless you do not mind paint everywhere. Spray light coats. The first coat of primer should not fully cover the wheel.
After first coat of primer (I used primer sealer).
2. Wait 5 minutes, spray second coat. Again, lightly.
3. Wait 5 minutes, by now you can see the wheel is almost fully covered expect a few spots (depending on design of wheel). Lay down final coat of primer.
4. Let the wheel sit for about 15-20 minutes. If you used sandable primer, you may sand it down after it dries.
<U>Step Six: Spray</U>
Spraying paint and clearcoat.
1. Lay down first coat of paint. Several light coats to avoid runs and overspray. Spray in a sweeping motion (While pulling trigger move left, release. While pulling trigger move right, release. Repeat.)
After first coat..
2. Wait 10 minutes, lay down second coat.
3. Wait 10 minutes, lay down third coat.
4. Wait 10 minutes, inspect. At this point, if the wheel is evenly covered with paint you may stop and let it dry. If not, lay down another coat and call it final.
5. After final coat, color should look even across the wheel. Let it dry for 30 minutes before laying down clear.
While you wait..........
6. Lay down clearcoat just like painting. But you may use several medium coats instead of light coats to pull out more shine. Don't go crazy with it!!
(Sorry, no pictures of spraying clear)
<U>Step Seven: Dry</U>
Drying your work. Most overlooked process when painting at home. Failure to proper drying may result in repeating a lot of work.
1. After the final coat of clear, let it sit about 30 minutes before you transfer them to a cleaner safer place to air dry overnight.
2. Dry it overnight indoors.
<U>Step Eight: Final Outcome</U>
Inspect for damage and flaws under the sun. If you satisfied with the results, kickback, grab a beer, a blunt, a dutch, a L, a joint, whatever you want, and admire your work. Just don't forget you got 3 more to go.
1. Pull off the masking tape slowly. Be paitent!!!
Mmmhmmm
<U>Optional Step: Polish</U>
If you want that polished area to really shine, metal polish (mother's stuff works great), a polisher and/or power mini ball. Buff it up. Read instructions on metal polish.
<U>Optional Step: Shine</U>
Now you polished the metal so good the paint starting to look dull?
You can wet sand your clearcoat with 1500-2000grit sand paper to get a smooth even texture on the painted area. You can also polish the painted area with a rubbing compound, polishing compound, followed by wax.
This is not required but you may do it down the road once the paint fully cures. Give it about 2-3 weeks.
I didn't do the optional steps since these wheels are going to be hitting snow and salt 24/7.
As long as you have some common sense and know how to read, this job won't be a problem. Hope this helps the folks that PM'd me about this info.
<U>Maintenance</U>
Poor maintenance can make your wheels look worthless real quick.
For the first week just wash them down with low pressure water.
After that, wash your wheel separately when you wash your ride.
I use soap water but you can use your favorite wheel cleaner.
<FONT COLOR="RED">SOAK IT, BUT DON'T LET THE CLEANER/SOAP DRY OUT</FONT>
You may start buffing after they dry.
For painted areas,
pick your favorite rubbing compound and/or polishing compound followed by wax.
For polished areas,
pick your favorite metal polish followed by wax.
Polishing might not be necessary for every car wash.
You can re-polish them once a month or whenever they get dirty or dull.
Both buffing steps can be done by hand but I recommend a buffer/polisher and powerball mini (works great on lips) for the best results.
Don't forget about the tires, get your favorite tire wetter and let 'em shine!!
<FONT COLOR="BLUE">KEEP 'EM CLEAN!!!!</FONT>
copied from: https://honda-tech.com/zerothread?id=316500
Originally Posted by PatrickGSR94
Since lots of people have been asking about my wheels, I figured I would make a how-to for everyone to see. First, I'll go through the process I followed:
1. Clean off wheels thoroughly, then lay wheel/tire flat on ground.
2. Scuff wheel with sandpaper, then clean wheel again.
3. Stick index cards around edge of wheel between tire and wheel to keep paint off of tires.
4. Spray several light coats of paint onto wheel. I used DupliColor Wheel Paint, graphite color, available from AutoZone, $4/can.
5. Spray several light coats of clearcoat if desired, depending on how shiny you want the final product to be. Clearcoat will also make the final finish feel smoother.
Now, after doing that, here is what I have observed needs to be done in addition to those steps above:
- Before painting, you should use an aircraft stripper to remove ALL original clearcoat and any paint that is on the wheel to begin with. Take it down to bare aluminum.
- Clean wheel, strip off clearcoat (use gloves, and try to keep the stuff off the tires), clean off residue, clean/wash wheel again, then paint as above.
- As far as primer, I'm not sure if that should be used beforehand or not. I didn't, but you might have better results if you use it.
And now the before:
And after:
*NEW EDIT*
I touched up my wheels last week, added a bunch more gunmetal paint, and this time I used a TON of clear on top of it. Now they have a wet look to them which I think looks really nice.
Modified by toyomatt84 at 11:51 PM 4/7/2008
Last edited by toyomatt84; Feb 9, 2011 at 08:52 AM. Reason: Merged two old threads.
Old Oct 25, 2002 | 12:56 PM
typeR#0427's Avatar
Default Re: How-to: painting wheels (PatrickGSR94)
thanks for the tip
Old Oct 25, 2002 | 01:09 PM
TRE_'s Avatar
Default Re: How-to: painting wheels (95AZ-GSR)
thanks for the tip
Ian, You need to do that to your car! Go wingless too! Looks ******* awesome.
Old Oct 25, 2002 | 01:26 PM
weakGOODJunKieS.com's Avatar
Default Re: How-to: painting wheels (HybridJDMHonda)
s2000 antenna?
Old Oct 25, 2002 | 01:33 PM
Homer_Simpson's Avatar
Default Re: How-to: painting wheels (importoverdomestic)
hey patrick,
could u post some close ups of the rims?? thanks..
Will-
Old Oct 25, 2002 | 02:18 PM
lilxvtecxpwr's Avatar
Default Re: How-to: painting wheels (*****rAcEr)
nice...i'd think they'd look better w/ the center caps though.
i've seen some si's that color, i think that **** looks really good, id sport em.
Old Oct 25, 2002 | 02:43 PM
Damon B.'s Avatar
Default Re: How-to: painting wheels (lilxvtecxpwr)
I feel like I see this car everytime I open a link...
Old Oct 25, 2002 | 02:57 PM
vtecnologist1's Avatar
Default Re: How-to: painting wheels (CleanSi)
yeah !!!!!! i see that thing everywhere
those pics are old too....
**** the rims, paint the car.....
Old Oct 25, 2002 | 08:26 PM
Community Builder
Default Re: How-to: painting wheels (chrisonepointsix)
huh? what are you all talking about? 1998? *shrugs*
I had painted my centercaps before the wheels, and put too much clearcoat... they look different than the wheels. I wanted to go with Si centercaps left unpainted but they don't fit right. Oh well, I like them fine w/o centercaps.
[Modified by PatrickGSR94, 11:28 PM 10/25/2002]
Old Oct 31, 2002 | 07:40 AM
ricodemus's Avatar
I'd just like to say thanks for the post. Looks good dude.
Old Oct 31, 2002 | 07:44 AM
KEVlN's Avatar
New User
Your car looks great in this pic Patty!
-kev
Old Nov 2, 2002 | 07:12 PM
Jesse H's Avatar
How is the finish holding up? Does it cheep or scratch easily?
Old Nov 2, 2002 | 09:27 PM
EpDarks's Avatar
Default Re: How-to: painting wheels (Jesse H)
Do you think the aircraft stripper is really necessary?
Some friends and I just sanded the wheel well, and never used any stripper, 6 months later it's doing great.
Just curious on what your thoughts are.
Old Nov 2, 2002 | 09:57 PM
SOHC_MShue's Avatar
Default Re: How-to: painting wheels (EpDarks)
nice wheels
Old Nov 3, 2002 | 04:42 AM
ebelp's Avatar
Good tips Patrick...that was basically my routine too. I didn't use aircraft stripper or primer though. My wheels still look as good as the 1st day and it's been about 2 months....
before
after
That 1st pic was the day after I put my Neuspeed race springs on....you can tell how much they've settled in the 2nd pic.
Old Nov 3, 2002 | 04:43 AM
ebelp's Avatar
Default Re: How-to: painting wheels (ebelp)
Well, maybe it just the grass in the second pic making my car look low....hehe
Old Nov 3, 2002 | 09:53 AM
boosting's Avatar
patrick, ebelp one of you sell me your rims!!
Old Nov 3, 2002 | 10:49 AM
Community Builder
Did your paint ever chip or flake off around the very outer edges (right up next to the tire)? If I had tires w/ rim guards, that area of my wheel might not be so exposed, but right now it is. I can take the paint off that area with my fingernail, because the OEM clearcoat is still around the outer edges of the rim, which is from me not being able to get to that part w/ sandpaper (the area where you stick index cards to keep paint off the tires).
Some of the paint also flaked off that same area around the edges when I had the car aligned awhile back (the laser devices that clamp to the wheel took a bit of paint off). I'm thinking that if I had used the aircraft stripper, all that OEM clearcoat would have come off and the paint would have stuck better.
Old Nov 3, 2002 | 11:04 AM
Superdragr45's Avatar
i have powdercoated wheels. is it harder to paint those than just the alloys??
Old Nov 3, 2002 | 11:12 AM
ebelp's Avatar
Default Re: How-to: painting wheels (boosting)
Sure, I'll take a trade for a set of bronze C8's!
Old Nov 3, 2002 | 11:30 PM
ElectronBlueGSR's Avatar
I think it's best to use 400 grit sand paper, that's what I did and it turned out great.
Here's a pic of some 96 GSR rims in DupliColor Graphite Gray
We did my friend's Impreza rims cuz he liked mine so much hehe
Old Nov 3, 2002 | 11:48 PM
iam7head's Avatar
Default Re: How-to: painting wheels (ElectronBlueGSR)
Here my version...
also some picture when i diy'ed..
painting the brake thingie..
saw off CAI
painting side skirt
leather kit installation
who's the DIY king now? jk
http://www.imagestation.com/album/?i...ulation_page=Y
oh yeah..some close up picture too!
[Modified by iam7head, 8:50 AM 11/4/2002]
Old Nov 11, 2002 | 06:42 PM
SMZ GSR's Avatar
PatrickGSR94 - Good info man, thats the same color i've been thinking about doing my 98 GSR wheels in.
Does anyone know if AutoZone carries other good colors? Like a good Bronze.
Old Nov 16, 2002 | 05:00 AM
xjohnx's Avatar
Just a tip, but in the future don't waste your time with the masking tape, just put a lot of armor all tire gel on the tires, any overspray will just wipe right off.
Old Nov 16, 2002 | 10:46 AM
illi Adik's Avatar
How easy is it to get the paint off if I would want to someday?
