What steering rack for DC2? no power steering
I am in the process of replacing my front subframe because i think it might be slightly bent. Since i'm replacing that would or should i replace the steering rack with a different one? I have a 95 gsr and i took out power steering and i just blocked off the hoses on the steering rack. I use this car for mostly drag racing only. I've heard that the civic steering rack will shave off 60lbs or so?
a manual civic steering rack wil fit, since they all share the same crossmember. be sure to put proper sized bushings in there, so there is NO PLAY
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dturbocivic »</TD></TR><TR><TD CLASS="quote">a manual civic steering rack wil fit, since they all share the same crossmember. be sure to put proper sized bushings in there, so there is NO PLAY</TD></TR></TABLE>
They will in fact bolt on to the same subframe, however the splines are infact different.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by regamaster »</TD></TR><TR><TD CLASS="quote">
They will in fact bolt on to the same subframe, however the splines are infact different. </TD></TR></TABLE>
im guessing you are talking about the splines on the steering colum?
Ouch.
So you need a EG steering column to use a EG steering rack? I just bought an EG rack for my DC and was told they share the same spline.
Ouch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked »</TD></TR><TR><TD CLASS="quote">
Ouch.
So you need a EG steering column to use a EG steering rack? I just bought an EG rack for my DC and was told they share the same spline.</TD></TR></TABLE>
ouch, lol gtfo
i know that i swaped a power rack to a non power rack, in my 92civic si. but i didnt change the spline piece. maybe the civic's are differant than the integra's??
Ouch.
ouch, lol gtfo
ouch, lol gtfo
i know that i swaped a power rack to a non power rack, in my 92civic si. but i didnt change the spline piece. maybe the civic's are differant than the integra's??</TD></TR></TABLE>
possible.....guess I'll find out.
ouch, lol gtfo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xtremeness101 »</TD></TR><TR><TD CLASS="quote">But you can use the coupler off the EG to make it work on the DC2 column</TD></TR></TABLE>
oh, OK. Well that's not too bad then.
thanks for the info.
Paul Bisioc
Jun 25, 2019 11:29 AM
fsp31
18
Apr 29, 2003 05:10 PM
