D4 light flashing and tranny idles rough
Old Aug 30, 2005 | 10:05 PM
hydeehydee's Avatar
Default D4 light flashing and tranny shifts rough
I have a 1995 Honda Accord EX...the RPM guage jumps back and forth and sometimes while driving idles at 0...a few days after noticing this issue the D4 light started flashing and the transmission started to shift roughly...both of these happened at the same time with no prior warnings...I was told it was the Transmission Control Module which I had replaced and did not fix the problem...does anyone have any other suggestions as to what the problem may be?
Old Aug 30, 2005 | 11:23 PM
F23Coupe's Avatar
Default Re: D4 light flashing and tranny shifts rough (hydeehydee)
A flashing D4 light ain't good. It usually means your tranny has serious problems. All of your problems can be related to tranny failure. I'd take it to a dealer or somewhere reputable for codes and maybe even a teardown.
Old Aug 31, 2005 | 12:48 AM
hydeehydee's Avatar
Default Re: D4 light flashing and tranny shifts rough (F23Coupe)
would the tranny jsut fail with no prior warnings...i mean everything was fine and I got on a ramp to enter the interstate and the light started blinking and the transmission was shifting hard....are there any other possibilities other than the TCM?
Old Aug 31, 2005 | 04:54 AM
v4lu3s's Avatar
RTFM
teh light flshing is like a check engine light. you cant realyl guess what is wrong, you need to pull the codes from teh TCM and see what is broken and go from there.
Old Aug 31, 2005 | 03:44 PM
hondadude's Avatar
This link might help you get the flash codes.
http://members.troublecodes.ne...n.jpg
Old Aug 31, 2005 | 03:50 PM
deserthonda's Avatar
who told you it was the tcm?? did they chk the codes before condemming the tcm??? i feel bad that u had to waste your money and still got problems . that is why i PREACH diagnose, diagnose ,diagnose before you **** money away then fix it right the first time ...read the code and post it here...
Old Sep 2, 2005 | 01:19 AM
hydeehydee's Avatar
Default Re: (v4lu3s)
can someone tell me in detail how to get the codes? I know where the 2 set of wires are with the connectors but I am unsure how to retrieve the codes...I saw the illustrated picture which had a "jumper wire" but where do I get this wire and how do I use it?
Old Sep 2, 2005 | 05:42 AM
under dash rt side below glove box ,,there is a 2 wire connector , jump it , put key on and read the flashes on the instrument cluster,,a long flash means a 10 a short flash is a 1 ,,
so 1 long 4 shorts would be code 14 ,,
Old Sep 2, 2005 | 12:07 PM
hydeehydee's Avatar
Default Re: (deserthonda)
what do i use to "jump" it?
Old Sep 5, 2005 | 09:23 AM
shrewz92's Avatar
Default Re: (hydeehydee)
Some small guage wire. I've un-bent a small paperclip and slipped it into the contacts BEFORE turning on the ignition switch. Then turn key to position I. Don't crank the engine (position II). Look for that blinking light, then count as has been described.
Dalang
Sep 25, 2008 07:21 AM
bearboy80
Sep 1, 2004 10:37 PM
jdmsteve2004
Jun 24, 2004 07:08 AM
LSintegra
Apr 9, 2003 07:01 AM
dave'sh22a4
Nov 9, 2002 05:28 AM
