Gsr in EK..(over-heating)
Old Aug 30, 2005 | 09:29 PM
Jdmglenn's Avatar
Default Gsr in EK..(over-heating)
the temp needle rises when the car is at a stop. Using a chipped P28 wiht obd 2-1 harness if that matters. The fan is hooked up and doesnt turn on... What could it be??
Old Aug 30, 2005 | 09:33 PM
handa's Avatar
Default Re: Gsr in EK..(over-heating) (JdmGlenn)
thermostat.
run your car for like 2 minutes...then check your radiator hoses (top and bottom one). top should be hot...bottom should be cool and you have a thermostat problem.
Old Aug 30, 2005 | 11:48 PM
hatchi's Avatar
check thermostat and the plug to see if it has continuity
Old Aug 31, 2005 | 04:19 AM
monicle's Avatar
coolant not bled completely would be my first guess. you follow the helms to fill up your colant?
Old Aug 31, 2005 | 06:24 AM
Jdmglenn's Avatar
well it was a fresh rebuild. Ugh we started it up and just started putting coolant in , then water, once it warmed up the coolant that was sitting at the top of where the rad cap goes sucked down, so we added more.
- Fan is connected, and the fan swtich by the thermo is hooked up.
Old Aug 31, 2005 | 08:19 AM
monicle's Avatar
Default Re: (JdmGlenn)
turn the heater on high take the radiator cap off and start the motor I bet you have a big air bubble in there. heater core will drain off a bit when you disconnect the lines. if the heater isnt turned on when youre refilling it it never fills back up.
Old Aug 31, 2005 | 08:35 AM
meanTheDope's Avatar
Default Re: (monicle)
im having the same prolem..with a chipped p30 ecu...cant figure this **** out...im gonna try to run the fan constant. see if that helps.
Old Aug 31, 2005 | 05:16 PM
Jdmglenn's Avatar
Thanks Monicle you solved my prob!!!
Old Aug 31, 2005 | 05:17 PM
jdmstreet88's Avatar
thermostat or possibly a clogged port
Old Sep 1, 2005 | 04:12 AM
monicle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdmGlenn &raquo;</TD></TR><TR><TD CLASS="quote">Thanks Monicle you solved my prob!!!</TD></TR></TABLE>
heh no problem. I was in your shoes a couple years ago and it frustrated the hell out of me.
hotcivicsi
11
Apr 9, 2009 06:19 PM
jwlee7ucla
Aug 7, 2007 03:48 PM
twenty
Jul 21, 2005 04:32 PM
twenty
Jul 21, 2005 08:36 AM
99 HXagon
Jul 21, 2002 09:13 AM
