Hi trap speed but crappy 1/4 time
Old Aug 30, 2005 | 09:06 PM
tub_sephiroth's Avatar
Default Hi trap speed but crappy 1/4 time
I'm running 100 mph trap speed but only running 14.5 in the 1/4 mile on street tires. This blows!!! This is on a boosted gsr. My 60 ft. was 2.279. I need to get into the 13's. Is this possible on current setup? If not, on slicks?
Old Aug 31, 2005 | 12:03 AM
90LSpimpin's Avatar
Default Re: Hi trap speed but crappy 1/4 time (tub_sephiroth)
Whats the setup? That trap speed is about right. Its gonna depend on your powerband; how long it is and when it kicks in. You can see my best times in my sig right now. Its a stock 89 si motor with custom turbo kit. Hit full 7psi around 4k and hold it to my 7k shift point. I would think the gsr should be faster? Hows the tune, do you have any boost leaks or anything?
Old Aug 31, 2005 | 02:31 AM
hondaguyef's Avatar
Default Re: Hi trap speed but crappy 1/4 time (89SiPimpin)
With slicks you could go 13's. You'll need about a mid 1.8 60 footer. I'm also assuming that you are spinning 2nd a little bit as well, correct?
Phil
Old Aug 31, 2005 | 07:25 AM
Default Re: Hi trap speed but crappy 1/4 time (hondaguyef)
I have a custom kit. The tune is fine at 7 psi. I get full boost around 4300 rpm. I'm getting 245 hp on the dyno. No boost leak and yeah, I am still spinning 2nd gear a bit.
Old Aug 31, 2005 | 09:03 AM
90LSpimpin's Avatar
Yea, if your puttin down that kinda power and its a good tune, then its mostly just driving. I think you should be able to get into the 13's exactly as you stand now. Just get some more runs in and try to feather it a little more into 2nd to keep the spin down. Good luck.
Old Aug 31, 2005 | 10:56 PM
JL's Avatar
JL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tub_sephiroth &raquo;</TD></TR><TR><TD CLASS="quote">This is on a boosted gsr. My 60 ft. was 2.279. I need to get into the 13's. Is this possible on current setup? If not, on slicks?</TD></TR></TABLE>
is this a gsr car or gsr motor.. im assuming its an integra.
depending on the weight of the car 245 should be good for 13s... my friends eg hatch weighing 2580 with a greddy kit on a jdm itr motor was going 13.2 @ 104 on 22x9.5x13s he had dynoed it ~220 hp on 6psi and turned it to 8-9psi when he was running the 13.20s.. pulling 1.8 60'
throughout the night he improved from 13.9 gradually to the 13.2, practice is good, and slicks
Old Sep 1, 2005 | 09:49 AM
vaporboy12's Avatar
Default Re: Hi trap speed but crappy 1/4 time (JL)
i went 12.85 on my first motor turbo set up it was an ls turbo making 263whp in a integra. with bfg drag radials. get some drag radials andjust keep at it
Old Sep 1, 2005 | 10:12 AM
Blown02Stang's Avatar
FWD's a bitch ain't it!
Old Sep 1, 2005 | 10:35 AM
vaporboy12's Avatar
Default Re: Hi trap speed but crappy 1/4 time (Blown02Stang)
not really just takes seat time
Old Sep 1, 2005 | 11:01 AM
kine462's Avatar
98 ex coupe full interior on street tires(drag radials)
d16y8 bone stock w/t3 @15psi = 13.2@101.36 and a 1.9 60ft. practice practice practice
also i am launching @ 5500 rpm w 5psi of boost (thank you launch control)
Old Sep 14, 2005 | 12:46 AM
torqueless's Avatar
with my old setup my best time was 14.3@101 on street tires. But w/20"slicks my best was 13.6@99 (crx)
Old Sep 14, 2005 | 07:29 AM
vtekthis's Avatar
blown02stang,
rear can be just as tough
92HB_HB
May 18, 2010 06:39 PM
V-SPEC 1
Jun 3, 2009 09:31 AM
Jared
Jun 25, 2004 09:35 AM
boostsohfast
Mar 20, 2003 10:57 AM
CRXRageD
May 6, 2002 08:27 AM
