IDLE problem need help quick
Old Aug 30, 2005 | 08:53 PM
hatchish's Avatar
Default IDLE problem need help quick
ok my car isn't idleing correct it acts like its not getting fuel. It will be idleing fine then it acts like it cuts out for a second but doesnt turn off. couple of days ago it turned off once at a stop light. also the check engine light came on and and it threw 14 and 1 which is 14 IAC (EACV) - idle air control valve and 1 O2A - Oxygen sensor #1 i cleared the codes from the relay and it has not threw a check engine light since i'm thinkin it's either EACV or fuel pump. what do you guys think?
Old Aug 30, 2005 | 09:04 PM
underb00steg6's Avatar
Default Re: IDLE problem need help quick (hatchish)
what year is the car? ...i think it may be the fuel pump
Old Aug 30, 2005 | 09:11 PM
hatchish's Avatar
92 civic hatchback cx with b16a and chipped teg computer
Old Aug 30, 2005 | 09:13 PM
Default Re: (hatchish)
92, then i would try changing out the fuel pump for sure, have you changed out the fuel filter lately?
Old Aug 30, 2005 | 09:46 PM
hatchish's Avatar
naw thanks for reminding me also arnt u supposed 2 upgrade the fuel line injecter that goes into the fuel rail cuz im still using all the cx stuff
Old Aug 31, 2005 | 07:15 AM
hatchish's Avatar
bump it
Old Aug 31, 2005 | 07:28 AM
siregcivic's Avatar
no... you dont need to do anything... haha jk.. eric use the fuel line from the fuel filter to the rail off a teggy gsr
Old Aug 31, 2005 | 09:21 AM
92eg6lsvtec's Avatar
Default Re: (siregcivic)
my car does this too, but throws a code 43 and i have ls/vtec swap in a 92 vx hb.
Old Aug 31, 2005 | 09:35 AM
hatchish's Avatar
im thinking its fuel related
Old Aug 31, 2005 | 09:37 AM
yea code 43 is fuel supply...
Old Aug 31, 2005 | 09:41 AM
hatchish's Avatar
no i meant did u upgrade ur fuel system like the fuel pump and the thing that goes into the fuel rail
Old Aug 31, 2005 | 11:06 AM
i didnt. it was running fine no problems awhile ago. now, its sputters and idles low. i have one of my vaccums off just so it idles a lil higher so that when im rolling up to a stop light in neutral it doesnt die. if the vaccum is connected it will drop to low in the rpms and die. i dont know whats going on but its pissing me off
Old Aug 31, 2005 | 11:55 AM
hatchish's Avatar
try using a different idle air control valve
Old Aug 31, 2005 | 12:41 PM
i changed my whole throttle body!!! still the same
Old Aug 31, 2005 | 12:52 PM
1dayCivic's Avatar
Is the car hard to start? A friend had the same problem, the in tank sock at the bottom of the Fuel Pump was really nasty and couldnt suck up fuel quick enough.
Old Aug 31, 2005 | 01:47 PM
hatchish's Avatar
92eg6 the idle air control isnt on the throttle body
Old Aug 31, 2005 | 02:19 PM
o the one on the intake mani... yea my bad, but still i really doubt thats the problem. also when im in 1st gear or 2nd and i accelerate like 1/3rd throttle it bogs, its not a solid power. its almost like its missing.
Old Aug 31, 2005 | 03:42 PM
hatchish's Avatar
check your timing thats usually the problem
Old Aug 31, 2005 | 04:37 PM
haha weve messed with the timing alot and its dead on(ignition and crank). the only timing that could be messed up would be if the timing in the uberdata changed itself or something.
Old Aug 31, 2005 | 06:44 PM
93Civac's Avatar
If it came up with a idle air control valve code, and your having problems with it idleing, dont you think that you should at least remove it and see if its dirty. Its only 2 bolts and may just be the problem.
Old Aug 31, 2005 | 07:09 PM
sagron69's Avatar
Default Re: (93Civac)
My car was doing that for a while, i checked the dizzy cap and rotor and poof, super oxidized so i changed them and the problem went away. Check the cap and rotor i'm sure that's the issue, and they're cheap from Kragen.
Old Aug 31, 2005 | 07:35 PM
Default Re: (sagron69)
i already checked my cap and rotor, both r clean. and know and its throwing code 43 for fuel, not idle air control.
Cheeseburgers
May 31, 2017 05:50 PM
rivoe302er
Mar 29, 2010 06:12 PM
JinteDgraM
Sep 6, 2006 07:11 PM
crnimacak
Apr 21, 2006 10:11 PM
